First HCH II Service at Dealer - Air Pressure
I finally went in for my first service at the local Honda dealer - Oil Change and Tire Rotation. The code popped on my display at about 7550 miles - 15% oil life and tire rotation required. I delivered the car at 8200 miles as I was driving north from Southern California when 15 and then 10% oil life appeared.
Anyway, my experience at the dealer was both good and newsworthy I believe. In rotating the tires, the dealer reset the air pressure in all tires to 32 psi. Checked them after the service. I recently set them at 40 psi. So something for all to be aware of when they take their HCH II in for service. Anyone else have that experience?
Re: First HCH II Service at Dealer - Air Pressure
They didn't adjust the air in my tires. It could have been because they assumed the higher pressure was due to the tires being warm, but knowing my dealer they were probably just lazy.
just fyi honda requests that we set the tire pressures in every vehicle at every service to whatever the door jamb sticker sugguests. and if we install honda factory option wheels it actually comes with a replacement sticker with the new tire size and recommended pressure
Same exact thing happened to me. I set the pressure in my tires at 40 psi also. When the service was finished, the guy told me they set the pressure to 32. I didn't think to tell him not to change it, and I can't fault the guy for doing his job. I just filled them back up when I got home.
I've had a slightly different experience not involving the dealer. I followed the excellent posts here and went to 40 PSI on all four tires on a brand new 2008 HCH. A month later, my TPMS indicated that I had low air pressure. The right front tire was only at 28!
I filled it back up and checked again - all at 40. Great. Two weeks later, TPMS comes on again, and this time it's the left front tire at 28 psi. What gives?
This isn't winter and I don't drive aggressively. My 5k miles lifetime MPG average is 49. Now, a couple PSI maybe, but a 12 PSI drop in both front tires, within weeks of each other ( verified with top quality mechanical tire pressure gauge ) , that can't be normal.
Jess - You were right, at least insofar as left front tire is concerned. Dealer could not find anything and sent me on my way. After less than five minutes' driving time, TPMS comes on again. Turned around and headed back to dealer. They found a "tiny pinhole" and fixed it.
Now, I am getting paranoid about the HCH II stock OEM's and overinflation. While I've only gone up to 40 PSI, this can't be a coincidence that I've had problems with two of the OEM's in the first 4k miles, when I've had maybe two flats in the previous 200,000K with my other, non hybrid cars with regular inflation.
I have around 26k on mine and I keep them at 44 psi. The only issue I've had his getting a nail in one of them on the way to have the oil changed. Haven't had a problem since.
mnsweeps
Toyota Highlander Hybrid
05-19-2008 01:00 PM
Devonaut
08-03-2006 01:29 AM
