Cylinder missfire fix or cat converter replacement?
06 HCH has codes: P0420- cat converter, P0304-cyl 4 missfire, P0301 cyl 1 missfire, and P0300 multiple cyl missfire, can i fix/replace cylinders and wait till 2 years for smog inspection to replace cat converter with no problems?? Car still works but struggles when electric assist is charging also leaks oil. Any advice is appriciated thanks !
You're not paying attention. Please refer to my first post - as I said, there are 8 plugs. They can look perfect and still not function. Unless you know they've been replaced in the last 60K miles WITH THE OE STYLE PLUGS, replace them.
I've encountered P030X misfire codes on 3X HCH2, and in all three cases, they needed new plugs.
https://www.rockauto.com/en/catalog/...park+plug,7212
NGK 4458
There's also a Denso P/N but I can't find it on RockAuto, and I can't get to denso's site.
If you buy them locally, they're likely to run you $14 EACH
NGK 4458
Axel Gumm
Jul 1, 2018 04:52 PM
TBaFFz
Jan 14, 2015 01:36 PM
mphillips
Jul 8, 2011 09:25 PM
