Civic Hybrid Running Lights.
Re: Civic Hybrid Running Lights.
Although I believe the two electrical systems are separate, even if they weren't it wouldn't really matter. The electric motors use roughly 15,000 watts when in use. You could run with your hi-beams on and only drain 130 watts. Less than 1% impact on the EV system isn't really going to be noticeable.
You'd see the same benefit by dropping 10lbs from your waistline. That might be harder, but for the majority of Americans (and presumably hybrid owners) it'd show much better returns.
http://www.cleanmpg.com/forums/showthread.php?t=1306
It would seem if you're that determined to cut down on costs or environmental impact, you should also be evaluating when you can take public transportation.
Too true, in my case about 50Lbs....
