In car power outlet fuse (for phone charger, etc)
Old Jun 5, 2007 | 12:05 PM
JJanney's Avatar
Default In car power outlet fuse (for phone charger, etc)
Does anyone have a diagram of the fuse panel containing the fuse for the two cabin power outlets used for phone chargers and other such things? I believe my Verizon cell phone charger blew that fuse. Thank in advance, jj
Old Jun 5, 2007 | 12:51 PM
Default Re: In car power outlet fuse (for phone charger, etc)
look in your owners manual for the fuse assignments. Also make sure that you did not blow the fuse in the phone charger cable.
Old Jun 5, 2007 | 01:19 PM
greenhome's Avatar
yea my verizon cell phone charger does that around once every 20 uses, i dont kknow if i put it it crooked and create a short or what be ready those fuses are tiny, in the 04 there is afuse puller in the fuse box you will need it or needle know pliers
Old Jun 6, 2007 | 03:44 AM
TheBundo's Avatar
My 400 amp invertor kept blowing the fuses too. Finally, I took a large sidecutter, and squared off a penny to the width of the fuse, and hammered it into the fuse slot. Works great now (learned that trick at my grandpas house back in the 60's)
Old Jun 6, 2007 | 05:11 AM
Scimitar's Avatar
Yes, it will work great up to a point where you may set fire to your wiring. Remember that the fuse is there for a reason. Anyhow, I trust you know. I advise that you at least put a drip tray under your wiring in case the insulation starts to melt.
Old Jun 7, 2007 | 04:53 AM
JJanney's Avatar
Turns out that both ACC fuses (28 & 29) were blown. I guess there are more people with Verizon's chargers out there then I thought. Thanks guys
Old Jun 8, 2007 | 02:06 PM
guicide's Avatar
Nerd
We had this discussion about a year ago.
I plug in the phone with the engine turned off.
talljetman2
Feb 16, 2009 12:56 PM
paweldryba
Oct 12, 2007 10:25 PM
J4MacDonald
Sep 16, 2007 10:05 AM
Galileo
May 23, 2007 09:31 PM
wallpad
Nov 7, 2006 11:42 AM
