Block heater installation ?
Old Sep 18, 2007 | 10:10 AM
danyboy741's Avatar
Default Block heater installation ?
Has anybody installed a block heater themselves?
In Honda's installation instructions, Step 29 says: "Because the battery is disconnected, you need to enter the Honda multi-matic feedback signal as described in the Service Manual."
Does anybody know what that means?
If one of you has the Service Manual, then could help me figure this one out?
Thanks,
Dan
Old Sep 18, 2007 | 12:41 PM
twuelfing's Avatar
Default Re: Block heater installation ?
you dont need to disconnect the battery. the block heater doesnt interface with the cars electrical system at all. just make sure not to short anything out.
When i installed mine the worst part was loosening the coolant plug where the heater element goes. I had to cut a breaker bar in half to get the leverage I needed in the confined space.
other than that it was a snap. I spent a couple hours total.
Old Sep 19, 2007 | 05:52 AM
danyboy741's Avatar
That's what I'll do, I won't disconnect the battery.
Thanks for the reply.
Old Oct 4, 2007 | 08:30 PM
Flash's Avatar
I posted a bunch of photos of my install (a friend did it at a local car shop so the only luxury was the car lift). This one shows the Battery area and really the cord just snakes around it so you don't have to disconnect the battery.
Squint
Jun 15, 2016 07:07 PM
ylax
Toyota Motor Corporation
Oct 30, 2009 03:54 PM
caholla
Mar 23, 2008 08:55 AM
rburt07
Sep 11, 2007 07:08 PM
efusco
Toyota Highlander Hybrid
Mar 22, 2006 11:47 AM
