A123 service
Old Jun 10, 2009 | 01:47 PM
Default A123 service
At what Kilometers did this service appear. 35,000 Kilometers for me! Seems early? $18.00 bucks a qt. x three for CVT fluid Hal
Old Jun 10, 2009 | 04:02 PM
larryr's Avatar
2nd Hybrid Owner
Default Re: A123 service
Here in Arkansas I paid $7.80 qt for honda CVT fluid. $18.00 is way too much.
CVT should be replaced around 20,000 miles or 30,000 kilometers. Much longer than that and it becomes sluggish.
Old Jun 10, 2009 | 05:21 PM
Hi Larry;
I would be around 25,000 miles as I actually had 38,500 Kil. on th dial. The oil was still clean with only a slightly darker red. Some grey sludge on the drain magnet. CVT preformed the same as the day I took it home. I purchased the oil at the Honda dealer! Hal
Old Jun 11, 2009 | 07:16 AM
The correct mileage interval for the CVT fluid replacement is 30,000 miles.
Old Jun 11, 2009 | 08:13 AM
mmrmnhrm's Avatar
Wo ai Zheng!
No, the correct mileage interval is whenever the maintenance minder tells you to. 30k is just the max Honda recommends before you do it anyways.
Old Jun 11, 2009 | 08:23 AM
Sorry, 30K is the interval. The MM is there simply as a reminder to perform the service.
Old Jun 11, 2009 | 08:37 AM
Well I only manage 24,000 miles and I am a easy driver! I did not expect this to pop up that soon, oh well can't win all the time! I guess I can contribute the low millage to the type of conditions I drive in! Lot of mountain terrain? I do what the MM tells me! I really like that tool! Best thing to happen to the Auto industry in a long time? My opinion, Hal
Old Jun 11, 2009 | 09:29 AM
Mendel Leisk's Avatar
Harold, I did our first CVT fluid change at 41129km, ahead of the Maintenance Minder. The MM asked for CVT change a bit later, at 46134 km. I explained to the Service Dept. that I'd just done it.
My reason for the first change was a pamphlet I picked up at the dealership, published by Honda Canada, giving guidelines for maintenance. Under the heading: "Specific Additional Required Maintenance", it says to replace CVT fluid every 48,000km or 24 months, FWIW.
I've since elected to change the CVT fluid yearly. This is purely my own preference. A typical drain and fill seems to require 3 US quarts, per the Owners Manual guideline. I would put in that amount and ignore the Owner's Manual guidance for hot check of the diptstick, which does not seem to work: it reads way too low. 3 US quarts should put it at the full mark on Cold Side of the dipstick.
Old Jun 11, 2009 | 01:47 PM
Thanks Mendel. Looks as if we are close. I actually had 38500 and most of my trips are on mountain passes. If it shows up again,like yours did, I'll just reset because that stuff is costly! $18.00 plus levy and tax. $100 dollars for 4 qts. shishhhhh! I was over two yrs.though! Hal
Old Jun 11, 2009 | 04:49 PM
3 quarts should do.
