2007 hchii with engine code errors
I need some help
Today my 2007 hchii with 76k miles
the check engine light came on with the ima light, brake light, steering light,
and my trans light was blinking while in "d". The engine was on and the tach was at 0
I got codes p16n5, and uo100
What do they mean? dealer could not help till next wednesday
Hey Brian;
Might be a good time to have Honda check it out and find out what caused this. Could be a pack,cat or something minor. You could also remove the 12v ground cable for about 15 min. and reset! But with all those lights coming on it does sound serious! Has the car been acting strange of late? H
Harold
Actual the errors, came after I did a power reset....I forgot to mention that...Dealer said that the check engine and others will go out after 3 on/off cycles.. and they did car runs greats...it just freaked me out with all those lights...They did not come on right away, only after about 1 min of driving. I had done the power reset in the morning and forgot that I had done it.
Thanks for the response
Brian
Brian
