Re: 2007 Civic Will not charge 12v no matter what
After going through everything on the car I ponied up and bought a DC to dc converter used on fleabay. Hot swap and I have 13.5v at the battery and a reasonably balanced pack. I wonder if this pack has been replaced at some point.
I'm happy as a clam. Time to get the rear seat back in and take her for a beat. Thanks S Keith. If you need anything let me know. Once I get everything ready assembled and clean i may post pictures |
Originally Posted by mrklean
(Post 262474)
I'm happy as a clam. Time to get the rear seat back in and take her for a beat. Thanks S Keith. If you need anything let me know. Once I get everything ready assembled and clean i may post pictures A nice tidy summary to end it all would be perfect. This one had me baffled. |
Well. The war is not over. The pack must not have turned out as well as I thought. 25 miles in the country at 55mph. Stopping hard and accerlating hard occassionally to clean the rust off the rotors and testing the Ima a respectively the Ima light came on.
P07af. Pack deterioration. Bah humbug. Right after I read assembled the back seat and washed it. Guess I counted my chickens before they hatched. Getting on it hard dropped the SOC meter about 5 bars. It comes back up when you allow it to charge but in 25 miles of flat country road I saw the SOC meter cycle two full times. Everything works as it should, even auto stop, and I averaged 42.4mpg in that time. I really don't want to pull the back seat and check taps voltages but I need to. Blech. Will report back in a bit... 'S Keith, do you happen to have the picture of the pinout for measuring the tap voltages? I can't find mine... |
1 Attachment(s)
I have a pack delta of .13 voltages. 181v at the mains. 16.38 to 16.51 at taps.
This can't be the cause of my light. I've attached a photo of the taps measurement from the service manual for my future reference. |
Unfortunately, resting voltages don't tell all the story. What's likely happening is that the delta gets pretty wide under load/regen, and the car is registering deteriorated usable capacity.
