2006 HCH battery temperature sensor
After reassembling my battery pack, I am not getting high voltage at the output terminals (car running and main battery switch on). I believe one of my temperature sensors is damaged, and am thinking that may be tripping the electronic interlock. Though it's possible some other error is preventing the high voltage, does anyone know what all the car checks that would prevent high voltage on the output terminals of the battery?
With the temperature sensor being the most likely culprit, I am looking for a replacement. Does anyone know how/where to purchase just the temperature sensor? Specifically, the yellow/black sensor is the one I believe to be damaged. They seem like standard thermocouples, is it possible I could just wire on a generic thermocouple to the wires and have it work?
Re: 2006 HCH battery temperature sensor
When removing the temperature sensor from the stick, it can be unclipped so that you can unwrap it instead of sliding it over the end.
192.168.100.1 192.168.1.1
accent2010
05-08-2022 06:45 PM
sherritp
03-04-2013 08:44 PM
kapo2004HCH
10-22-2010 06:30 PM
