06 HCH died on start- reset- works fine now?
Old May 21, 2012 | 07:09 AM
hertfordnc's Avatar
Default 06 HCH died on start- reset- works fine now?
I had drive the car a short distance and shut it off. when i restarted it a few minutes later it fired up and then died.
There was a flashing green key symbol on the dash but all the lights were flashing so I'm not sure that was unique.
I restarted the car with the valet key and it seemed to sputter a bit before coming to life.
It's seems to fine now.
I used the carto jumpstart my truck yesterday, i may have strained the 12 volt battery but this all happened after a 25 miles drive which should have topped the 12v batt off pretty well.
Old May 22, 2012 | 04:30 PM
GordonLightfoot's Avatar
Default Re: 06 HCH died on start- reset- works fine now?
Your starter battery is very small and won't take much abuse, like starting a truck. A weak 12v battery will cause all kinds of strange things to happen.
It will probably be ok once it is recharged properly.
GL
Old May 22, 2012 | 06:55 PM
hertfordnc's Avatar
Turns out ot was nothing. I am using a small lawn tractor battery ($36). It's been working great for a year but the connection had to be modified and that what was causing my problem.- the car would start and then the vibration would break the battery connection and the car would freak out and die.
I tightened the connection and the car is fine.
Yes, you can jump a big vehicle with your HCH. In warm weather even a small battery is sufficient to turn a V8 but it's a good idea to connect the cables and let it charge for a while.
Also, when you connect the cables you will get no reaction form the engine like you do on a regular car- there is no alternator so no load on the engine when the dead batttery is attached.
Old May 24, 2012 | 07:07 PM
Rickhandling's Avatar
Using another car with jumper cables is generally frowned upon especially with a hybrid or any late model car. Use a portable battery starter/charger next time. You're placing an abnormally large electrical demand on a car's battery and alternator.
Once you've let a car battery go dead, you permenently lost 25% of it's life. This isn't a about math. Letting a battery go dead several times really diminishes its life.
Old May 25, 2012 | 02:12 AM
hertfordnc's Avatar
By that math if you let a car battery go dead four times it would never recover?
Agreed, not a good idea to run a battery down to nothing but these things happen.
If you need to jump another car with your HCH the key is to let it charge the dead battery for a long time- like 30 minutes before attempting to start it.
If you're really paranoid you could let it charge the dead battery and disconnect the cables before starting the dead car.
minghi
Feb 27, 2012 12:54 PM
Freeze
Jan 1, 2007 07:09 AM
Droid13
Sep 2, 2006 08:51 AM
