P0134 02 sensor - no activity
Old Mar 3, 2011 | 01:34 PM
scole01234's Avatar
Default P0134 02 sensor - no activity
Hi
Is there any way of telling which 02 sensor I need to replace, when I run my diagnostics I have an output from 2 02 sensors.
If I do not replace this will I cause any damage to my car?
Any advice would be appreciated.
Old Mar 5, 2011 | 12:54 PM
scole01234's Avatar
Default Re: P0134 02 sensor - no activity
Can anybody tell me if there are 2 02 sensors on a 2003 civic ima manual, if there are 2 are they the same as each other as i can only see 1 listed in uk.
thanks
Old Apr 19, 2011 | 01:28 PM
scole01234's Avatar
Still struggling on with this problem. Is the 02 sensor easy to replace? I have read on the net about cleaning the EGR valve as this can cause false readings, is this likely to help? My engine does go off on its own sometimes when engine hot but comes on again 1st thing in the morning and my car seems very sluggish even with the light out. Any advise would be welcomed.
Steve
Old Jul 31, 2011 | 05:40 PM
houstoib's Avatar
The P0134 sensor is for the front O2 sensor, the wideband expensive one.
I just replaced mine, only to find in 15 miles a p1433 and p1600 code with CEL and IMA indicator on indicating my IMA battery was deteriorated. I can't understand how changing an O2 sensor would do that, or perhaps it was just really bad timing. I've asked in another thread for help with that.
So, based on my experience, I wouldn't touch the O2 sensor if you didn't have to. Clear your code and hope it goes away.
The only downside: your car won't run as efficiently, and you'll be putting off increased NOx emissions and won't pass an emissions test if CEL is on. Will it hurt your car: no.
Old Aug 3, 2011 | 01:31 PM
houstoib's Avatar
thanks
There are 2 sensors. Upstream (wideband) and downstream of the catalytic converter. You can see them both if you look behind the engine on the exhaust manifold. The upstream is right there and easy to access. Downstream a little more difficult but still accessible.
Both are available on Amazon:
upstream: http://www.amazon.com/Bosch-13680-Ox...2004&carId=001
Downstream: http://www.amazon.com/Bosch-15408-Ox...2004&carId=001
kapo2004HCH
Oct 22, 2010 06:30 PM
MyPart
Apr 10, 2009 09:26 AM
