Does anyone here knows where it is located the PCV Valve on a HCH 1?
I have three days searching all over the web trying to find the location of the PCV Valve on a 2004 honda civic hybrid, and still cant find it. In pepboys they told me is in the back of the engine, my mechanic says is in the front; but i cant find it in the front, back, or in top of the engine.
Please, any help will be widely appreciated,
Thanks.
Thanks.
. Thanks a lot Gairwyn.
Found another link; maybe you don't really have to do what the manual is saying:
http://answers.yahoo.com/question/in...1160929AAj0AQw
So far I haven't found a link from one of the Honda online parts websites that shows a good picture of this, but if I find one I will post the link here.
So far, still no luck with the Honda parts websites, but here's a pic of an engine bay ('03 and '04 are similar enough for this explanation):
http://www.motortrend.com/roadtests/..._02.html#photo
To the extreme right is the 12V battery, a bit more to the left, the cover for the air cleaner element, a bit more to the left, the IMA cover, etcetera.
If you remove the IMA cover, and look just to the left of the large hose coming from the air cleaner element, you should see the location of the PCV valve. There is a small hose attached to the PCV valve. You should be looking straight at it. I wish I could explain it better, but that's the best this girl can do.
Edwin, I sent you another message.
Why don't you ask over at www.cleanmpg.com and see if anyone there has replaced the PCV valve on their HCH I. Maybe there is an easier way to get to it.
It is under the intake manifold. I just replaced it. My MPG was down to 32mpg. It shot back up to 40 now. The reason I replaced it was I was burning a lot of oil.
It took me 2 days and was very frustrating. I took off a lot of unnecessary bolts. Follow these guidelines.
1. Remove plastic covers.
2. Remove throttle body. 4 bolts.
3. Remove 3 bolts and 2 nuts holding on intake manifold.
4. Here is the hard part. Remove 2 bolts holding the intake manifold from under the car. These are very very hard to get to. I drained the radiator because I thought I would have to remove a hose that was in the way. It turned out, I removed the bolt without taking the hose off. Go after the 12mm bolts, not the 10mm bolts.
5. You do not have to take the manifold out. Just pull it back far enough to get the PCV valve out.
6. My PCV valve was clearly plugged. Good Luck!
