Does anyone have the schedule?
Old Oct 3, 2006 | 05:41 PM
Hot_Georgia_2004's Avatar
Default Does anyone have the schedule?
Does anyone have the maintenance schedule up to 100,000 miles?
You know, the things which need to be checked/serviced and at what mileage.
Thanks in advance.
Old Oct 3, 2006 | 07:22 PM
IMAhybrid's Avatar
Vegetarian
Default Re: Does anyone have the schedule?
From OwnerLink, for ~10k/year:
Every 10k
Oil change and rotate tires
Every 30k
Replace air cleaner element
Change CVT fluid (that wasn't on there but I know that's what it is... by the way, I can't believe Sparky is a CVT, very impressive.)
Every 3 years
Replace brake fluid
Check oil and coolant at each fuel stop
Check tire inflation and condition once a month
for more extreme: (every 10k?)
Replace engine oil filter
Check front and rear brake wear
Check parking brake adjustment
Inspect tie rod ends, steering gear box, and boots
Inspect suspension components
Inspect driveshaft boots
Inspect brake hoses and lines (including ABS)
Inspect all fluid levels and condition of fluids
Inspect exhaust system
Inspect fuel lines and connections
Inspect lights and controls/vehicle underbody
I know this probably isn't exactly what you're looking for... you're looking for the list of things that come with that $$$ XXXk service right? Unless just inspecting things costs that much... Nevermind this probably is the right thing.
Old Oct 3, 2006 | 09:31 PM
realist's Avatar
I remember reading somewhere (maybe in the car 'manual'?) that you should follow one of two different schedules depending on how rough you treat the car. I don't have that book in hand at the moment though. However, I do have...
From the service history booklet:
10,000 miles or 1 year:
Replace engine oil.
Rotate Tires (independent of time).
Reset Maintenance Required Indicator.
20,000 miles or 2 years:
Replace engine oil.
Rotate tires (independent of time).
Replace engine oil filter.
Check front and rear brake wear.
Check parking brake adjustment.
Check tie rod ends, steering gear box, and boots.
Check suspension componenets.
Check driveshaft boots.
Check brake hoses and lines (including ABS).
Check all fluid levels, condition of fluids, and check for leaks.
Check exhaust system.
Check fuel lines and connections.
30,000 miles or 2 years:
Replace engine oil.
Check drive belt.
Raplce dust and pollen filter.
Replace air cleaner element (independent of time).
40,000 miles or 2 years:
Replace engine oil.
Check suspension components.
50,000 miles or 3 years:
Replace engine oil.
3 years:
Replace brake fluid, independent of mileage.
60,000 miles or 3 years:
Replace engine oil.
Check drive belt.
Replace dust and pollen filter.
Replace CVT fluid.
70,000 miles or 4 years:
Replace engine oil.
80,000 miles or 4 years:
Replace engine oil.
90,000 miles or 5 years:
Replace engine oil.
Check drive belt.
Replace CVT fluid.
100,000 miles or 5 years:
Replace engine oil.
Check drive shaft boots.
6 years:
Old Mar 23, 2008 | 05:44 PM
Estoril73's Avatar
"Manalo"
The schedule mentions of checking coolant at each and every fuel stop, but really who does that?
Does anyone know the scheduled interval for flush/replace coolant? Every 60k? 120k?
schitzengiggles
Oct 7, 2012 12:42 AM
noflash
Jun 20, 2008 12:50 PM
JOE540CI
12
May 27, 2008 06:10 PM
greeneagle
Dec 13, 2007 07:29 AM
JOE540CI
Dec 9, 2006 02:20 PM
