creaking when steering
Old Nov 28, 2009 | 09:24 AM
GeneValgene's Avatar
Default creaking when steering
hello all,
my wife's 2003 hch just started doing this. basically when you turn the wheel either way, it starts creaking pretty badly. you can feel the vibrations slightly in the wheel. while trying to find something on the web, i came across this guy on youtube with the EXACT same problem
anyone know what might be causing this?
http://www.youtube.com/watch?v=ctjGL...eature=related
http://www.youtube.com/watch?v=QtAmJ...eature=related
http://www.youtube.com/watch?v=wruyQ...eature=related
Old Nov 29, 2009 | 05:13 AM
ovals49's Avatar
Default Re: creaking when steering
I had occasion to explore the steering column on my 2005 HCH when I was having problems with what turned out to be a faulty steering rack. the steering column is supported by bearings and then articulates at the firewall with a universal joint. Either of these might be the culprit.
Although it is a bit difficult to make the sound out clearly on the YouTube clips, it sounded a bit like plastic rubbing on plastic. It also sounds like it originates in the passenger compartment rather than in the engine bay. Any chance the plastic steering column trim has been displaced so as to make contact with the turning steering wheel? Could a bit of debris have found its' way in there? You might try removing the plastic column trim pieces, top and bottom, and see if the noise stops in order to narrow down the list of possible causes. It could be something that simple.
Here's a link to an site where you can find exploded drawing of the trimpieces (and the rest of the car): http://www.bernardiparts.com Once you enter basic model info go to the "interior bumper" section, then the "instrument panel/garnish (driver's side)" assembly drawing. There are three or four screws on the underside of the column trim. You might need to move the tilt of the wheel up or down to get clearance, but other than that it's a pretty simple procedure.
rkr
Jun 20, 2011 06:46 PM
lifespeed
Aug 4, 2010 05:39 PM
jwltch
Apr 8, 2009 12:21 PM
ntguru
Nov 27, 2006 01:25 PM
kenny
Jun 23, 2004 08:53 AM
