Crank no start Honda Civic hybrid 03
Old Mar 6, 2018 | 02:20 PM
Jass-Kitten Smith's Avatar
Question Crank no start Honda Civic hybrid 03
My car will crank but won't start. I hooked up a presupre gauge and have none. My car will start for a minute with starter fluid. I unhooked the fuel line from the pump and turned the key and it shoots out fuel.
Old Mar 7, 2018 | 12:18 PM
pasadena_commut's Avatar
Default Re: Crank no start Honda Civic hybrid 03
"none" == 0 PSI???? That would suggest that the motor isn't even turning, or the block literally split in half, but those are not consistent with it "running for a while with starter fluid". Find a way to safely observe the motor so that you can verify it is actually spinning when an assistant tries to start it.
Normally the car starts with the small electric motor. If the IMA battery is too low it will try to start with the starter motor. Starter motors sometimes fail by locking, so that when the ignition switch is turned nothing happens. If it is trying to use the starter motor and the 12V battery is very weak it may not crank enough to start.
There are a lot of things that could be wrong here:
1. fuel (you showed that the pump works, maybe no signal is getting to the injectors?)
2. no spark
3. blocked air intake
It probably isn't a blocked exhaust, that would start and run briefly before stopping.
If this started suddenly perhaps check the fuses and make sure that none involved in running the motor are blown. Also check that the 12V battery is functional. If you don't have a voltmeter or battery tester just try jump starting it.
Nordic Flyer
Jul 24, 2019 02:25 PM
drewbacca503
Aug 23, 2018 08:16 AM
stotta87
Dec 27, 2016 11:24 AM
kirkpk
Nov 13, 2016 09:50 AM
FredGRN
Jun 27, 2015 07:50 PM
