Broken Tail Light
Old 09-28-2006, 07:55 PM
bigbearballs's Avatar
Default Broken Tail Light
Does anyone know where to get a cheap replacement? Is it the same as the regular Civic, 2 door and 4 door? Thanks!
Old 09-28-2006, 10:02 PM
Default Re: Broken Tail Light
It's not the same for the 2 door. You might want to check 7thgencivic.com Someone might have some to sell. Make sure you get the right one though. I think the 01 and 02 will fit, but isn't exactly the same.
You can check compatibility by going to hondaautomotiveparts.com and seeing if the part numbers match.
Old 09-29-2006, 05:57 AM
Great, thanks.
Old 09-29-2006, 01:48 PM
yutafl's Avatar
I just had to replace my pass side taillight and went to www.directauto.com. Honda changed the look of the tailights in 03, so though I think 01-02 will fit, they'll look different (no circles in the lens).
When replacing it, be careful of the nuts securing the taillight. I had to shimmy the rear bumper off of it's tabs in order to get access from underneath. Good luck!
Cheers
Old 10-01-2006, 08:15 AM
70 bucks,
Old 10-04-2006, 07:46 PM
Part numbers don't match, in fact the Hybrid taillight is $30.00 more. It's $97.24. MF. This hurts, what a mistake backing into a trash can.
Old 10-04-2006, 07:55 PM
yutafl's Avatar
Here's an excerpt from my email receipt on the taillight I used. It fits, and it matches the other side perfectly. Dunno why the hybrid taillight would be more expensive... unless it's for the new '06 since the LED taillights are a hybrid exclusive.
Good luck!
HTML Code:
Name                  Code          Qty   Each  Options
Brand New Tail Light  TLA164R         1  72.55  Style = 2003-2004 Honda Civic
Assembly # TLA164R                              Passenger RH sedan Tail light #
(Shipped)                                       TLA164R
Old 10-04-2006, 08:03 PM
Hybrid...
regular civic
Old 10-04-2006, 08:04 PM
Those look different, I got them from hondaautomotiveparts.com.
Quick Reply: Broken Tail Light
