Bizzare re-cal?
Old Aug 18, 2006 | 01:54 AM
lakedude's Avatar
Default Bizzare re-cal?
My car died after a long FAS and would not restart. The display got all kinds of goofy and the charge indicator went from about 2/3rds to nothing flat in a few seconds. When the SOC hit zero I think the 12V starter kicked in and the car finally started after about 10 attempts. It drove normally after the ordeal.
Old Aug 18, 2006 | 04:55 AM
ralph_dog's Avatar
World's First Hybrid
Default Re: Bizzare re-cal?
Maybe a loose connection somewhere along the DC high voltage power buss..or someplace else...???
Old Aug 21, 2006 | 06:43 PM
AshenGrey's Avatar
Hybrid True Believer
I had a similar experience two weeks ago when I did a bunch of FAS in heavy traffic. When the IMA battery hit zero, I stopped manually turning the car off and the battery charge began regenerating after a few minutes. It hasn't had the problem again, however.
Old Aug 21, 2006 | 08:42 PM
tbaleno's Avatar
I've seen flickering and stuff when the 12v was not putting out enough voltage.
Old Sep 5, 2006 | 05:17 PM
ovals49's Avatar
If I'm not mistaken, the 12v battery, which is quite small in capacity, does not have available to it the power in the IMA battery to maintain it's charge level unless the key is in the "run" position. A long coast with the lights and accessories on, but the engine off, can quickly run down th 12v battery to a point where it no longer can support the onboard electronic brain, and strange things begin to happen. One of these things will be the IMA battery suddenly displaying NO charge. (There still is plenty of juice in the IMA battery, but the electronic brain can no longer ascertain that fact.)
When the 12v battery dies, jump starting the HCH simply entails repowering the electroinic brain so that when the key is turned to the run (or start) position, the IMA power again becomes available. It is the power in the IMA battery which powers starts and restarts of the engine, not the 12v one. Also, the depleted 12v battery will be recharged automatically, and quite quickly, courtesy of the IMA battery, as you drive. It's quite an elegant system!
Old Sep 7, 2006 | 02:10 AM
lakedude's Avatar
So you think the 12v battery was the problem and the car started from the main pack? I was thinking just the other way around, that the main pack died and the 12v kicked in......
Any way to tell the difference? The car started with the IMA pack showing completely dead, (I think).
BTW I've had no further trouble, the car seems fine...
a2t
Apr 22, 2015 05:29 AM
donald_s
Aug 9, 2006 06:13 PM
these_go211
Aug 11, 2005 11:12 PM
manolomm
Introductions
May 23, 2005 10:15 PM
l3ement
Introductions
Jan 16, 2005 08:56 AM
