Adding Transmission filter
I just bought a used 2004 HCH I. It has 159k miles on it but it was an original owner and he was a service manager for a honda deal so I know the maintenance was all done. The battery was just replaced and the engine has great compression. And at $4500 I think it was a steal.
Anyways my question is I have found some aftermarket in line transmission filters where you cut a hose line for the transmission somewhere and add it in.
Has anyone used one of these?
Does anyone recommend adding a filter to the CVT trans?
I thought it might be a good idea since it has no filter stock.
he is an example of one
http://cgi.ebay.com/ebaymotors/2001-...Q5fAccessories
The drain plug has a good size magnet on it and will pick-up metal parts. The fluid in the CVT is normally changed every 20 k miles. My oil looks new when I drain it. Apparently there is a filter inside the CVT and I have herd of only one person changing it! I would not go to all the effort! H
twolostminds
Nov 17, 2014 06:23 AM
dgyimao
Dec 31, 2009 09:38 AM
bugs
May 26, 2009 12:05 AM
