5 speed auto stop
I read in the Insight forum that if you put the manual 5 speed transmission into neutral at any speed the engine stops, so is a good way of achieving fuel efficiency.
Does this happen with HCH I ?
I guess that in this mode there is no regen braking available?
no it doesn't happen at any speed with the HCH I. mine usually will go into autostop at about 10-12 mph when slowing down, but i put it in neutral on hills, and it doesn't turn off.
If you happen to catch the engine-off neutral at the top of a hill, have fun! I've gotten to about 60 mph with the engine off before I needed to stop at the bottom (keep the clutch engaged to keep the engine off above 20 mph).
