Tahoe hybrid won’t stay running
Old Apr 10, 2019 | 01:51 PM
Jorjans79's Avatar
Default Tahoe hybrid won’t stay running
Hey my name is George. I currently own a 2008 Chevy Tahoe. when I crank the engine it stay running for about 10 to 15 seconds and then it dies. after that it just crank a little bit but it doesn’t fire up , if I wait 2 to 3 hours it will do the same thing, I don’t have any codes, any help will be appreciated. Thanks!
Old Apr 14, 2019 | 05:13 PM
dnt1010's Avatar
Default Re: Tahoe hybrid won’t stay running
The Hybrid system fools a lot of people in the same exact manner. The engine is actually cranked via a dampener assembly (The Two Mode 2ML70 trans uses a dampener in place of a torque converter)
The engine is cranked by one of the two transmission interior electric motors at a high rpm and what you are seeing is just the engine being turned over at around 700 to 800 rpm it NEVER actually starts. You have a engine problem probably just a bad fuel pump etc. Now that you know what to look for it should be an easy fix.
Old Apr 15, 2019 | 07:57 PM
Tahoe_08's Avatar
you are having engine issues
the only way to know for sure it to see the live data stream
Old May 14, 2019 | 03:33 AM
Tahoe_08's Avatar
there is a TSB
It Says Operator Error
Stall During Shift Out of Park Immediately following Engine Crank
This is a normal operating characteristic. Some drivers are able to interrupt the engine start sequence by immediately shifting the transmission out of Park after turning the ignition to Crank. Because the electric motor spins the engine so fast, the engine may appear to be running immediately after Crank but the ECM has not yet started spark and fuel. The ECM will turn off fuel and spark to the engine if it is not running and the transmission has been shifted out of Park or Neutral. Inform the customer to wait 1-2 seconds before shifting out of Park or Neutral to ensure that the engine is running and has completed the start sequence.
Engine Restarts in Reverse/Manual Mode from Auto Stop
if it's still not starting it's not doing the start up sequence
not getting fuel or spark
Old Jun 12, 2019 | 07:06 PM
Chicago38's Avatar
It looks like I have the exact same problem. After turning the key, I hear the operation of the electro motor arrow rises but the gasoline engine does not start for this reason the electric motor shuts off after about half a minute
Old Jul 21, 2019 | 11:41 AM
angiecharan650's Avatar
Hi George, we are currently facing the same issue. Our mechanic has advised that the hybrid battery is failing us!
Old Jul 22, 2019 | 04:50 AM
Tahoe_08's Avatar
you will be swapping out for nothing
I would look at the 12V+ battery first before anything else
I would try and use starting fluid
it's basic trouble shooting like a normal ICE
he is trying to scam you into buying a HV battery it would not even spin the electrical motor if it was bad
also make sure the engine crank shaft is spinning other wise the connection to the transmission has failed (you can see the belt spin)
try via remote start
Be careful of the fans and spinning objects
Old Jul 29, 2019 | 12:53 PM
Jorjans79's Avatar
You are right. It was my 12 volts battery. Thanks!
Old Dec 11, 2022 | 03:55 PM
Gbaby's Avatar
I have a question because I have a 08 Tahoe that cut off on me at the top of a road. When I got it home it would start for about seconds then turn off then it wouldn’t do anything at all if I wait it will do the same thing. Now it won’t turn over or anything. And do all hybrids make a noise when they first start up?
Old Dec 11, 2022 | 06:17 PM
???'s Avatar
by noise do you mean start the gas engine? then yeah they always start the gas engine at start up. runs for longer when cold and only about 30sec something when already up to temp. but it does need to run the engine, they won't act like say a volt that just turns on in electric mode and goes. also if the hood is open it will always run the engine and not go into auto stop electric mode.
from this thread it sounds like checking the 12v is the easiest thing to do. they seem to cause people random trouble. I guess I got lucky, when my 12v went dead, it just died. the truck wouldn't start, nothing funny happened before or after, just tested it and it was dead, like 6v or something bad. replaced it with another I had laying around it it's been fine since.
