Sierra Hybrid Weirdness
Friday, I started my truck and it returned a "Service Tire Pressure Monitoring System" message on the DIC. At the time, a look at the tire pressures on the DIC indicated no reading (a dash by all four tire readings). This issue disappeared on restart.
Saturday, upon starting, the DIC displayed a "Service Power Steering System" message, then the engine died (NOT auto stop - the tach fell to the zero peg). This issue continued on subsequent restarts.
Acting upon the suspicion that a weak 12V battery might be making for misbehaving modules, I replaced the 12V battery. Another start attempt yielded the same results, with the engine failing to stay in operation.
I tried another restart with the hood open(which will cause the ICE to run continuously), but it would not stay running.
Anyone ever experienced a similar set of conditions?
Re: Sierra Hybrid Weirdness
Apparently, the computer, if it can't "find" a running ICE, decides the world is ending, and displays all kinds of messages.
The TPMS error on the previous day remains a mystery, although it hasn't happened again.
Lesson learned: 1. Don't run low of gas. 2. Don't make emotional diagnostic decisions. The rule is "horses before zebras". If I had thought that way to begin with, I would have saved purchasing a 12V battery.
Thanks again!
-J
I agree, ive run this truck out of gas and all sorts of odd things occur!
Regarding tire pressure system, for some reason, mine is wired wrong. When it says LF tire, its actually reading RR tire. And so on. Anyone else have that issue ?
The one I just did yesterday after a rotate was to key to Run and then hold down the lock and un-lock buttons on the remote key fob. The horn goes and DIC says something about learning active. When you do not have the service tool $$$, you are supposed to be able to let air out until the horn goes indicating it has it learned. Then move to next tire.
You start with left front letting air out until horn. Then Right front, then right rear and left rear last.
The tool works better but I have done it manually.
MMH06
02-19-2010 07:08 AM
