ordered my volsnt intake wed
Old 03-06-2010, 08:59 AM
jet1's Avatar
FLY NAVY!
Default ordered my volant intake wed
got here friday! of course thurs i had my left rotator cuff repaired and the tendons reattached that were torn away,,,,,I dont think i will install it any time soon...
Old 03-07-2010, 06:16 PM
kklein's Avatar
Default Re: ordered my volsnt intake wed
Jet 1 hope you feel better. Make sure all the parts arrived, my kit was missing parts. Its about 2 hrs to install, not to bad at all, looks great and you will see a MPG improvement.
Old 03-09-2010, 03:21 PM
kklein's Avatar
Volant Engine Modification Pictures.[ATTACH]ordered my volsnt intake wed-volant-mass-air-sensor.jpg[/ATTACH]
Old 03-09-2010, 03:25 PM
kklein's Avatar
I could drop in and install it for you!!!!
Old 03-09-2010, 07:06 PM
jet1's Avatar
FLY NAVY!
Default thanks for the pics and offer...
but it can wait....I havent even driven it in a week!
Old 03-10-2010, 04:27 AM
kklein's Avatar
Hope things are mending.
Old 03-10-2010, 06:13 AM
Hillbilly_Hybrid's Avatar
Does the mass air flow sensor come from Volant or do you re-use it?
And I'm volunteering to keep Jet's baby company if he can't fly for a while.
Old 03-10-2010, 12:54 PM
jet1's Avatar
FLY NAVY!
Default maf is reused
just slightly different plumbing and air box
Old 03-10-2010, 01:27 PM
Thanks. I see in Ken's pictures that it appears to be a large bore and large radius to the throttle body. Should increase flow. Air turns corners better with larger radii. Also no Helmholtz Resonators. The factory puts in those funny shaped appendages to reduce induction noise for pass by db regulations. Volume, length, and opening area = Hz.
The sound should be quite different. Hopefully a nice V8 roar not a 4 cyl MOO.
Old 03-10-2010, 03:02 PM
kklein's Avatar
It has a nice V8 roar and you reuse the mass air flow sensor. I used the carb shop flow chamber to check it. The chamber is designed for stromburg carbs (Radial Engines Carbs), No a requirement just wanted to make sure the set point was the same and would work, its fine.
Quick Reply: ordered my volsnt intake wed
