Nav Display Noise
I have notice that sometimes my Nav Display CD will run off and on several times and then stop. I have no problems with the Nav system now that I know how to use it. Just wondering if other owners have experienced this?
Thanks for the information Jet 1, it is interesting once I have put the truck in reverse with a blank screen and when I went back into forward everything worked.
![Zip](https://electricvehicleforums.com/forums/images/smilies/emotikons/zip.gif)
![Smile](https://electricvehicleforums.com/forums/images/smilies/emotikons/smile.gif)
When the ambient light detector decides the sun has set (maybe because a tree is shadowing the sensor where you parked), it will turn on the headlights and dim the dash lights to where you set them. Being a good pilot, you were trained to keep them as dim as possible for the conditions. Now, if that was a dark night, you will find the display basically invisible. Doubly so with sunglasses on (I'm sure you have a pair of Ray Ban Aviators).
Just crank the dimming **** next time, this happens to me all the time...
Actually I think it's just the head unit getting its self "confused". I've had the display do odd things if I put the truck in reverse then forward and reverse again (backing into a one car garage can be a pain with the beast). Everything resets its self the next time I start her up so no harm really.
![Omg](https://electricvehicleforums.com/forums/images/smilies/emotikons/omg.gif)
The other day my driver's door wouldn't open even though the vehicle was in park. I couldn't get out while dropping the kids off at school. Disengaging the driver's door is a safety precaution so that you don't get out while in drive with the engine on autostop. But I was in park and it still would not open. So I had to unroll the window and open it from the outside. I guess it was just a glitch since it has not done it since (knock wood).
