installed the volant intake today
you really need two fully functional arms! fits ok but is not perfect and required some body trimming (where the bottom cold air duct fits. its kind of a wrestling match when you can only use one arm for leverage. its def. louder if you really punch the throttle ...filled up and reset all the mileage to do a test. more to come......
Hi Jet congradulations and first class based on your injury. NKG Iridium, mmm we had iridium in aviation 30 years ago its okay, better technology exsists. There is a lot of room for ingnition, intake, and fuel injection system improvements. Best example a current aircraft injected piston engine by Continental or Lycoming has fuel injectors with maybe a 15-10% tolerance take that with the cylinder tolerance and in a eight cylinder engine maybe one is running at peak while the other are running lean of peak or rich of peak. Peak = Maximum EGT for best performance optimum fuel burn for best performance. Now an Aviation company called Gaime developed a procedure and injector to match each cylinder to reach peak EGT at the same time resulting in a decrease of fuel used and an increase in performance, by how much I have seen 25-30%. Big differance.
Could anyone please tell me which Volant CAI will fit a 2009 Tahoe Hybrid(if any)? I contacted several vendors before contacting Volant tech support directly and they all told me there isn't one that will fit the 2009 Tahoe Hybrid. I was told there is a difference on the mass air flow sensor from 2009 forward and the one they have will not fit and not to try it because it wont work. i'm assuming that if this is true all of the volant cai's I have seen have been on 2008's, which they claim they do have a cai for.
Thanks Much,
Thanks Much,
Thanks Much,
Thanks Much,
what is so different of the volant from the stock airbox? is the design more aerodynamic, straight, bigger diameter, etc? I know a few members have tried it and attest to have improved mileage but have not yet jump the gun and buy one risking the warranty and all(1st GM product).
Good morning Jet1,
Did you have any clearance issue while trying to install the intake to the Throttle Body? I purchased an Airaid Jr kit designed for 4.8, 5.3, and 6.0L engines and the initial bend off the Throttle Body would not allow it to fit with the resivor in front, so I sent it back.
I may try it and see if i can make it work for my 2009.
