CNG----FAILED so far
they cannot mount tanks under the car and give me enough volume to make it worth while. they CAN mount tanks in the back but I would lose 14" of the rear floor (4 tanks across and slightly higher than the folded seats) with a custom built cover it would not be readily apparent that there was any difference but I would lose several cubic feet of cargo and also the use of the rear most seats (which I took out when I got the car and stored in a closet) I can't quite decide what to do.....
I have decided to put four tanks across the rear floor and sacrifice the space a bit. I think it is the socially responsible thing to do for many reasons and the rear seat loss isn't a big thing. Now the yukon has to last 6 years more for sure! its on the schedule for the 19th of dec. so I will report more then
Well of course do what you want ... but it may be that the universe is trying to tell you something.
Some folks listen to those hints, others see them as a dare.
Btw, why are you doing a new thread for each post?
Might be easier to keep track of the project under one thread.
I don't know anything about CNG conversions ... but don't they normally remove the gas tank and convert the vehicle to CNG from gasoline?
I would imagine that's where they would normally install the new CNG tanks.
what to do
it is converted to a 3 mode gas/electric/cng engine always starts on gas then switches to cng,,,,if in electric mode the car works like it normally does the added dimension is that after it starts on gas it switches over to cng
Not familiar with the underside of your ride - where is the gas tank in relation to where you want to put the CNG tanks? Is it possible to replace with a smaller tank to make room for more CNG? You'd cut your total capacity some, but might have room for CNG plus some gas?
