2011 Tahoe Hybrid Reliability - HELP
![Exclamation](https://electricvehicleforums.com/forums/images/icons/icon4.gif)
I am considering purchasing a 2011 Tahoe Hybrid for my wife but read some scary reviews regarding:
1) the braking system, and brake failure, and
2) the engine completely shutting down
these problems seemed to stem from the 2008/2009 models. so my specific questions are:
1) has Chevrolet recognized these issues and addressed them in the 2011 model?
2) have any of you experienced these failures or any OTHER significant defect that would make me reconsider the purchase?
THANKS!
THANKS!
From what I have observed most of the significant issues were symptomatic of the 08s ... which is somewhat understandable in the first livery of such a complicated machine.
I've had no major problems with my 09. I did have the dreaded engine shutdown, but mine was caused by human error when someone did not reinsert the hybrid battery disconnect safety lever properly and it popped out whilst driving over NYC potholes. The only engine repair was the replacement of a bad throttle body under warranty. No brake issues. Oh and my driver door lock actuator went poof, which is a legendary issue with all the GM full size suvs, but which GM has apparently remedied by replacing the guilty part supplier.
Hope that helps a little.
mjfrance,
Those issue were resolved, and they were on some of the 08 models.
No issues with my 2010 Tahoe for the past 2 years.
I had the same concerns when I bought mine as well![Smile](https://electricvehicleforums.com/forums/images/smilies/emotikons/smile.gif)
Hope this helps.
Hope this helps.
I have a 2009 and no issues at all and have been cranking lots of miles already with nary a hint of failure. they replaced the battery a year ago when it died while listening to the nfl playoffs with key in ACC and xm radio on while detailing the hybrid.
I appear to own the resurgence of shutting down and brake failure. Own a 2010 Tahoe Hybrid. Was in the shop for a month, with GM engineers trying to figure out what the problem was, before it was finally resolved. That was June 2011. A week ago, the brakes went. I have no faith in this car and would never purchase one like it again.
Have an 08 Yukon Hybrid. At 62,500 started running ragged. They replaced the entire engine. Got a 76,000 mile truck with 12,000 on the engine! Still the original brakes. Had them checked during routine PR last week, and they said only about 60% worn. Get about 21 mpg.
4K thus far on my '13 and loving it. had some quirks I had to recognize as normal behavior. mpg is pegged at 18.5 winter time hauling 80+ lbs per corner due to my bigger wheel/tire setup.
![Name: photo_zps79d48226.jpg
Size: 147.3 KB](/forums/attachments/gm-hybrid-trucks-cadillac-escalade-hybrid-chevrolet-tahoe-hybrid-gmc-yukon-hybrid-69/2690d1501529566-2011-tahoe-hybrid-reliability-help-photo_zps79d48226.jpg)
Last edited by KC135R; 03-01-2013 at 07:08 PM. Reason: added parenthetical comment
