2009 Chevy Tahoe hybrid issue
Yesterday on my wife’s way home her check engine light started blinking. About 1/2 mile from home, she drives home and her car starts shaking.
It’s throwing two codes p0521 and p0307. Yesterday it had oil, today it seems to be low on oil. I have replaced the spark plugs (all of them) replaced the coil pack for plug #7. It continues to still make these noises, tomorrow I plan to replace the spark plug wire for #7 and add more oil. |
Re: 2009 Chevy Tahoe hybrid issue
1 Attachment(s)
Here is the sound
It’s a bad lifter. I just did mine.
Originally Posted by Tadds
(Post 268705)
Originally Posted by Andrew Lefebvre
(Post 268729)
we replaced the lifter, tick is gone, now we are having two issues, it says “low oil pressure” and when we start it white smoke comes from the tail pipe. Any idea? |
low on oil
Originally Posted by Tahoe_08
(Post 268989)
low on oil
White smoke is coolant. Head gasket leak.
Blue smoke is oil. Rings or valve guide seals. Black smoke = incomplete combustion. Fuel mixture issues. |
(Post 268993)
that doesn’t explain the white smoke
it's part of the combustion process at lest a cup of water pours out of the rear muffler every time I fill up the gas... piss everywhere no consumption of the coolant... Do a consumption test mark it with a marker if it stays the same your good. OR you got screwed with watered down gas (water in the ethanol ) Yes scam stations figured out the perfect ratio of gas to water mix to scam you out of money or have a lot of water mixed in your gas tank this is a good explanation of what Condensation is. |
Did you find out why you had white smoke? Mine did the same thing which was a cloud of white smoke. wasn't a coolant leak.
Originally Posted by Tripleog1981
(Post 269057)
only something to worry about if your losing coolant ... Just check it frequently to make sure you not losing any :) it's just like when you can see your breath in the winter time |
