2008 Chevy Tahoe Hybrid Brake Failure
Canuck,
Glad to hear there were no injuries, and you are safe after this incident.
Thanks for sharing this video, very informative.will check on mine, and see if theer are any signs of wear and tear
I hope someone from the forum can forward this to GM management.
Thanks again
Thanks again
Canuck,
Every customer is important to us and we apologize in advance if you were not treated correctly by your dealership. We will certainly investigate your case. When you are back online please post the last 8 digits of your serial number and if you don't mind, your servicing dealer and we will review your file and have someone contact you.
BQM GM Canada
BQM GM Canada
it looks like the brake line is waaay too far from the said bolt end. either a jack or lift must have caused the damage than constant up and down of the shocks. flexible tubing is usually in place for areas like these.
Canuck
Glad no harm was made to you or your family with this failure.
Nice Vid by the way, very Explicit.
From what I can see, It is not a silverado failure. I just went under mine, and no bolt will ever touch the brake lines even on full suspension compression.
Now, we have a couple of hybrid tahoes, and one 5.3L flex fuel tahoe. They all have the same suspension, so your failure could be related to all Tahoes, not only hybrids.
From this pic I can see that bolt 1 is the one that wear out your brake line.
Tomorrow I'll go under the tahoes and will try to take some pics out of them.
We don't use them to tow, but full passenger and cargo, will have the same effect on bumpy roads.
Thanks for the heads up for all of us.
And, try not to give up on GM just for a few ***** that made to work with them ! just my 2 cents
Canuk,
I went under the 2 Tahoes, and they have the same brake line type. One is 09 and the other 10.
The brake line is bended in a way the bolt will never touch it.
For what I can see in your video, your OEM brake line is straight. No clue why. When I have some time I'll check the 2008 Flexfuel tahoe.
Here are some pics. They might look alike, but are from both Trucks.
Again, sorry, It looks like you are flying solo on this one
If I found anything else I let you know.
btw, the Brake line had a number 25906100
Canuck,
I tried to use the gopro to make a video, but I really suck at it.
Got a pic and a little vid.
You can see how the pics is like 125 degrees wide angle !
http://youtu.be/w3PvZAhn-f8
Volquinum
50
Nov 17, 2018 04:49 AM
H-Bomb9000
Mar 7, 2015 09:33 AM
Realization
May 21, 2012 12:15 PM
