oil pressure gauge question
Hello! I just have a question. When my car is idling or running in the electric mode the oil pressure gauge is at zero. When running with the gasoline part it's fine. Is this normal, or should the oil pressure be showing above zero at all times? Thanks for your help.
Keep in mind "delete" and "disable" is two different things. Deleting would mean switching out the cam, lifters and valley cover to completely rid the engine of the AFM systems mechanical aspects. There's probably other things that need to be switched out as well but not too familiar with the entirety of the process.
erick.oc
12
Jun 30, 2020 12:35 PM
PRYUKON2008
Dec 4, 2017 07:03 AM
schmidtj
Jul 9, 2012 03:13 AM
yohan55
15
Jan 31, 2012 07:41 PM
nicka
Feb 22, 2009 08:57 AM
