2008 Yukon can bus communication failure
Before data busses, every little sensor and switch basically needed its own wire. For example, inside a driver side door you may have window switches for the whole car, a door open/closed switch and the unlock/lock switches for the central locking system. Just those things would normally require 9 separate wires, and that's before you add
Tutuapp 9apps
Tutuapp 9apps
khaled
Oct 25, 2013 06:22 AM
