Re: Working towards 1000 miles on this tank
Originally Posted by VaBeachPrius
(Post 127723)
Diamondlarry,
I wasn't asking for credit. :D I was just curious to see if I had helped you. I have seen what you can do with a Saturn and if I am correct, you are on your first tank with the prius and kicking butt. It wil be easier and slightly more accurate if I use a SG rather than comparing before and after MFD displays for segment mpgs. My best segment was with a cold start up, I didn't use my block heater and I still averaged 103.x mpg. That took me two hours. My mileage would be higher with more time on the loop with a block heater. Good job right of the bat. Technically, I'm working on my second tank. I topped off when I got home from the dealer so I knew the tank would be full. Then, 4 days later I noticed a discrepancy between my SG and FCD and realized I had forgotten to change the tank offset setting from when it was in the Saturn so I topped off and started over again. I can see that this tank won't be 1K miles as I'm at 5 pips at just shy of 500 miles. |
Originally Posted by bwilson4web
(Post 126524)
With the weekend, you're within spittin' distance. Time for a 'road trip' to Ocean City? <grins>
I just don't remember if there is a minimum speed on the Chesapeake Bay Bridge Tunnel. Bob Wilson By the way, unless it was his commute, would taking a road trip specifically to get 1000 miles on a tank not be a waste of gasoline? |
Originally Posted by Shining Arcanine
(Post 128085)
By the way, unless it was his commute, would taking a road trip specifically to get 1000 miles on a tank not be a waste of gasoline? Bob Wilson |
Bob,
I don't think I will be traveling to the eastern shore anytime soon; It is amazing to me that I haven't pumped gas for almost a month! I am only at 692 miles at 84.9 miles. I just went from four to three pips. I should be at 800 miles my Friday afternoon and if I make 1000; that should occur by next Thursday. |
(Post 128137)
I don't think I will be traveling to the eastern shore anytime soon; It is amazing to me that I haven't pumped gas for almost a month! I am only at 692 miles at 84.9 miles. I just went from four to three pips. I should be at 800 miles my Friday afternoon and if I make 1000; that should occur by next Thursday. Bob Wilson |
How many pips are in your gauge?
Have any Prius owners made it to 1000? |
Originally Posted by Brady
(Post 128151)
Have any Prius owners made it to 1000? Bob Wilson |
I went past 1000 this morning. I will post a picture this afternoon when I refill.
(Post 129955)
Bob Wilson |
