Working towards 1000 miles on this tank
I am working towards 1000 miles on a tank of gas in my 2006 Toyota Prius. I have six pips left. I just thought I would throw in a picture of the progress:
http://www.cleanmpg.com/photos/data/...m/DSC_7097.jpg |
Re: Working towards 1000 miles on this tank
My best wishes and GOOD LUCK!!!
Getting 1,000 miles from 11.9 gallons normally requires an average of a little over 84 MPG. My target is to achieve a sustained 90 MPG before making the attempt. Bob Wilson |
Bob,
I started cold today and drove 62.4 miles for a before / after calculated 103.3 mpg for that segment. I know that I cannot maintain that for another 540 miles, but if I could, I would end up with a 92.x ish mpg tank. We shall see. |
Good luck with your endeavor! Do you have another vehicle you can drive if the weather gets crappy? Rain or cold will kill your tank.
I got lucky with a long hot dry spell and made it 1005 miles on 12.3 gallons in my "mild" Honda Civic Hybrid. Most of the driving was at 40-45 mph or so but at times I was just barely crawling over the tops of some hills. https://www.greenhybrid.com/share/fi.../1000miles.jpg |
Originally Posted by VaBeachPrius
(Post 126491)
I started cold today and drove 62.4 miles for a before / after calculated 103.3 mpg for that segment. I know that I cannot maintain that for another 540 miles, but if I could, I would end up with a 92.x ish mpg tank. We shall see. I just don't remember if there is a minimum speed on the Chesapeake Bay Bridge Tunnel. Bob Wilson |
Hey Chris,
Nice segment! I assume you based this on the MFD before and after your segment for MPG and used the trip A or B before and after to calculate the 103.x segment. Or do you have a scan gauge or other instrumentation? Any way good luck! I have managed 83.x over a tank last Sept and pulled off a shorter 103.x segment, but I don't think I'm in quite the same league as you. |
dcoyne78,
I have thought about getting a SGII, but I am simply trying the best I can with before and after mpg readings and doing the math to figure out segment mpgs. I don't think it is being fair to yourself to say that you are in a different league. There are a host of variables (including driver skill) that comes into play. As many others have proven (bob wilson); slowing down increases the fuel economy of this car. The trick between where I think Bob wilson is and where I stand is that I am trying to apply this to roads with many other cars; stop lights, and stop signs over 50 miles a day rather than over a closed course. If I had the patience and time; I could go knock out a 1200+ mile tank; but can I drive by myself in a closed loop for 50 hours straight. No way. I have to go to work. I am a dad of one and within three weeks the second will be here. I have been passed by a kid on a skateboard when coasting to a stop sign. Do you have that luxury in your commute where you can slow down; maybe not. I have just under 10000 miles on my car. I went through a cold winter without blocking the grill of my car. You will be in a league of your own when you and only you fully understand your commute and find ways to maximize your segments. Like teddygirl in Japan; if I had a 15 mile commute where I could average 25 mph with little traffic and few stop signs, you would be hearing me talk of 90+ mpg tanks. I might just do a mini marathon by myself to prove this point. |
Congrats, Chris. Stay with it. Flag, Barker or Priority?
Thanks. Priority. They gave me $1000 less than MSRP when $500 below was considered good.
(Post 126988)
If I had the patience and time; I could go knock out a 1200+ mile tank; but can I drive by myself in a closed loop for 50 hours straight. No way. I have to go to work. . . . The key is getting the car through the warm-up as quickly and efficiently as possible. Using a block heater, transaxle heater and thermistor hack, this should be entirely possible. But it would be more interesting to determine what is the optimum 'warm-up' profile. The other technique is to tickle-charge the traction battery to 80% (actually 78%) of peak. This is a trickier technical problem but IMHO no more or less valid than pre-heating the block and transaxle. Bob Wilson |
