Ford Motor Company Ford, Mazda and Mercury hybrids
Grid charge Hybrid Battery
Old Jan 2, 2021 | 06:54 AM
Automate's Avatar
Default Grid charge Hybrid Battery
Measured at the emergency disconnect, my 2010 Fusion Hybrid HV battery is down to 133 V.. I assume this is full voltage and not for some reason measuring half voltage.
Is there a relatively cheap grid charging method I can use to charge it back up to 270?
Old Jan 2, 2021 | 02:37 PM
Default Re: Grid charge Hybrid Battery
Why would you assume that's full voltage? When you check the voltage of a 12V battery, how do you do it? You measure between the main terminals of the battery.
Old Jan 2, 2021 | 04:26 PM
Automate's Avatar
My thinking is the safety switch should be breaking both main battery leads, but looking at it again, it only breaks one wire.
Old May 4, 2024 | 10:44 AM
DeanMassye's Avatar
eride1
Sep 17, 2020 05:35 PM
toast64
Mar 11, 2019 01:07 PM
paulk
Jan 25, 2018 03:58 PM
jjh1
Feb 21, 2016 06:36 PM
pmaster88
Toyota Highlander Hybrid
May 30, 2015 08:00 AM
