Water Pump Replacement
Old Oct 10, 2013 | 06:37 PM
howudodat's Avatar
Default Water Pump Replacement
I am looking for some help on replacing the water pump on my 2010 FFH. The repair manual makes it look too simple, of course. It says simply remove the coolant reservoir and voila a few bolts later the water pump comes right out. HAH. I cant even get my hands in there to work on it.
Tips anyone?
Peter
Old Oct 11, 2013 | 08:42 PM
lolder's Avatar
Default Re: Water Pump Replacement
Are you sure you have the manual for the hybrid? It looks like the DC to DC converter might be in the way. If it's the right manual, when you get the reservoir and hose out of the way maybe it's accessible. Why do you need to change it? That's pretty soon and is covered in the US by the power train 5yr./60,000 m. warranty.
Old Oct 12, 2013 | 07:33 AM
howudodat's Avatar
the cd says it's for the Fusion Hybrid
After removing the reservoir I had just barely enough room to get the pulley off, and the pump unscrewed. But now I can get the pump to budge at all. Pulled all 3 screws and it just wont move
yes it probably would be covered by the warranty, but I'm 40k miles past the warranty She just turned 100k
Peter
Old Oct 12, 2013 | 03:53 PM
lolder's Avatar
It may be stuck on a gasket.
Old Nov 15, 2013 | 02:47 PM
I just replaced mine in a 2006 FEH @192,000. Did it on GP.
The pump is very hard to get out. The O-ring that seals the pump body holds it tightly in the bore making the pull very difficult. You have to pull virtually straight out, which is almost impossible given the very limited access.
I broke off all three bolting tabs. I had to come up from the bottom and down from the top to walk it out. In the end used a prybar against the triangular mount plate for the pulley.
You'll find the replacement pump is slightly smaller and will go in easily. It doesn't take much to make it easy.
I put a dab of anti-seize on the new pump body, so that next time it'll be a touch easier... If this one goes 192,000 before replacement it may take awhile before I post that replacement!
Old Nov 25, 2013 | 10:13 AM
howudodat's Avatar
I finally got the old pump out by using my air chisel with a dull tip. The high speed tapping of the air chisel allowed the pump to vibrate out.
Peter
PriusPurveyor
Aug 24, 2020 08:29 PM
GeorgiaHybrid
Apr 11, 2018 10:22 AM
ian w
Apr 20, 2017 06:57 PM
Fastforward
Aug 11, 2013 05:27 PM
ukrkoz
Mar 11, 2012 04:30 PM
