when to use L range in FEH
I am wondering if there is a thread discussing the use of L vs D range. I have discovered when in L it slows up the FEH without using brakes in stop and go town traffic. I could not seem to find anything about it in the on line operators manual. Thanks for some information.
Re: when to use L range in FEH
http://www.cleanmpg.com/forums/showthread.php?t=350
GaryG
Thanks Gary! Probably take me awhile to digest some of your knowledge on the FEH. We really like it except the belt driven air conditioner vs our Prius electric driven unit. I guess if we wanted that part bad enough we could have gone in debt for a 2010 FEH. I thought for less than one half the cost of a 2010 we could get a loaded 2006. Besides we will use it more in colder weather. Do people use grill blocks in FEH like they do in a Prius? I know that on Priuschat they discuss blocking the grill in cold climates. Thanks again.
Yes. Unlike the Prius, your 06 FEH has a hybrid battery heater that can be utilized with option 41H--if you have this option installed.
You found all there is about it... it slows down the car by sending charge to the battery. It isn't a "Range" as on normal cars. I use it all the time to slow down, as you do, and to keep speed in down grades. Keep in mind that once you battery is full, the car will start sending all that extra power to turn the gas engine, at which point if it start going too high on revs I turn back to D again for a while and use my brakes a bit.
But it does not have any kind of "reduction" to help you go up hills or anything, it's more like an electric brake.
https://sites.google.com/site/feh07a/
regenerative braking. Not sure if FEH is similar but I have seen at least FEH display
gives BIGGER arrow showing more energy into hybrid battery. Since Ford uses 80% of Prius patents; I wonder how variable the regeneration mode can be exercised to eliminate almost all brake pad wear!! CDbear
An old thought:
"Since Ford uses 80% of Prius patents;"---
Ford's hybrid hardware and software was developed independently and is not shared by Toyota.
I had mine checked at a few months ago at 60,000 miles and the guy asked me when I had them replaced. I smiled and said that I just don't use the friction brakes very often, due in large part to using L and timing traffic lights better than most people. He thought that at that rate they will last to at least 200,000 miles. We'll see, but I am hopeful!
