What tire pressure are you hypermilers using?
Old Jan 19, 2006 | 07:54 AM
MMooney's Avatar
Default What tire pressure are you hypermilers using?
I'm running 44 - 45 psi. Anyone getting any benefit from running more?
How much more might this tire - wheel combo tolerate?
Anyone done coasting tests at higher psi?
MM
Old Jan 19, 2006 | 10:54 AM
livvie's Avatar
Default Re: What tire pressure are you hypermilers using?
I ran a test on my HCH were I used +5psi over recommended and the other test I used MAX (tire) psi. My FE did not improve going to MAX. What did improve though was handling and braking. At the expense of feeling more bumps.
Old Jan 19, 2006 | 11:35 AM
Pravus Prime's Avatar
Prof. of Hybridology
Personally, I usually go with 44, and I check the first of every month. As a reminder, recommended is 35.
Old Jan 19, 2006 | 01:06 PM
livvie's Avatar
Wasn't the Lexus H the first AWD?
Old Jan 19, 2006 | 01:13 PM
I'm Insulted!
The Ford Escape Hybrid was the worlds first Hybrid SUV, and America's first Hybrid.
It came out in the Fall of 2004.
It comes in 2WD and 4WD.
BTW, I run 49psi in all tires, and get great coasting results, and would have to expect better results all around.
With 49 psi, and even a 1% slope, the FEH will roll a long, long ways.
-John
Old Jan 19, 2006 | 02:09 PM
hardifeh's Avatar
FEH fan
Anyone using something other than Continental tires? And do they make a difference?
Old Jan 19, 2006 | 02:33 PM
livvie's Avatar
Originally Posted by gpsman1
I'm Insulted!
-John
hehe... my mistake but thanks to Volvo and Toyota, Ford finally came on board.
Old Jan 20, 2006 | 05:34 PM
rcomeau's Avatar
HI,
Maybe this is a silly question but... Aren't you supposed to use the recommended tire pressure because that's what pressure the tires are designed to be at? Will the higher pressure lead to different (degraded) grip and handling and uneven tire wear (wear faster in the middle)? Will it present a higher failure rate?
Just my thoughts. I am all for improving milleage but I see a lot of talk in these forums about high tire pressure, coasting with the engine off etc. with little discussion on potential safety (IMHO).
Cheers,
Roch
Old Jan 20, 2006 | 05:45 PM
tbaleno's Avatar
There could be any number of reasons a manufacturer recomends a tire presure. Remember the Firestone suv tires that were "bad" turns out ford recomended a preasure too low for that tire on that car. At least thats what I hear. They could recomend it based on load, noise, comfort, or any number of things.
Old Jan 20, 2006 | 06:18 PM
xcel's Avatar
