what HID headlamps for the FEH
I was looking at these http://www.coolbulbs.com/HIDKits_body.asp
They are not cheap though but they are not just those colored bulb rip-offs.
HID is an acronym for High Intensity Discharge and is basically a type of a gas plasma discharge lamp like some of the big screen projectors use. I'm not sure if there are any L.E.D. headlights out on the market yet, correct me please if I am wrong. Yes the LED's would use less current.
Simply dropping in an HID bulb/kit is not the best idea. HID lenses and housings are specifically designed to direct that type of light and beam pattern. Patrick is right that it would take a headlight re-design to pull it off.
As far as LED headlights, they are few and far between. Yes there are a few high end sedans that are beginning to look like they spec LED headlights. However for many of them they are for low-beam or DRL only.
True HID systems have a self leveling system that keeps them from blinding other drivers. Just installing "aftermarket" lights does not give you the levelling feature. I don't believe that any aftermarket HID lights are street legal.
lars-ss
Nov 7, 2006 06:13 AM
