what happens when you throw transmission into PARK at 35 mph?
Old Aug 1, 2008 | 06:27 AM
Brooke's Avatar
Default what happens when you throw transmission into PARK at 35 mph?
answer: Nothing
Went to shift from LOW into DRIVE on the expressway without paying attention and overshot; ended up in PARK. What happened? Although I thought the transmission would fall out, actually only thing that happened was that I could not shift back into DRIVE while I was moving forward (although I could drive normally). Pulled over into breakdown lane, stopped, shifted, and took off again.
Smart computer! Thank you to the Ford engineers!
Old Aug 1, 2008 | 07:03 AM
MyPart's Avatar
Default Re: what happens when you throw transmission into PARK at 35 mph?
Did you try shifting out of park while you were pressing the brake? I know that you have to do this when parked and shifting from P->D so this condition may need to be true in this case as well.
You probably don't care to try again and find out, do you?
On the same note, I think shifting into R while moving forward has a similar effect. The computer now checks for several conditions before allowing reverse activation. Thanks for confirming that it does the same for park.
Old Aug 1, 2008 | 02:09 PM
ddderek's Avatar
Greenie
I'll take your word for it... Do not try this at home... errr, or on the road!
Old Aug 1, 2008 | 02:35 PM
There have been reports of drivers accidently shifting into R while driving on the highway with no real changes/damage. I have to admit, I actually did this in January 2008. I drove forward about 5 seconds (speed under 25 mph) while the shift lever was in "R". I was able to shift back to "D" without stopping the vehicle.
Old Aug 4, 2008 | 01:59 PM
AA2070's Avatar
Good to know that the FEH is smarter than this. I accidentally did this in a 2008 Buick rental at about 85 MPH in Wisconsin about a year ago... horrible noise, and the car shut off. When I restarted it, reverse didn't work anymore and the car would only go about 25mph forward.
frankthomas
Jul 5, 2011 08:46 PM
2008 Honda CIvic Hybrid
Feb 15, 2008 11:39 AM
Tim K
Jul 8, 2006 04:16 PM
Ari Ben Canaan
Apr 19, 2006 08:27 PM
bwilson4web
Apr 1, 2006 12:23 PM
