Vibration at 2000rpm - 2009 FEH
Last week I purchased a 2009 Ford Escape Hybrid FWD, it was a dealer demo model with 30k km (19k miles).
I've noticed a very clear vibration, both in feel and audibly, between 2000 and 2200 rpm. I can feel it in the steering wheel and pedals. Speed seems irrelevant, I can be accelerating from a stop or cruising on the highway. And that rpm seems to be the most common when not running on battery, so it happens often. It almost seems like that rpm hits a resonance frequency with the body.
Before I start to push the dealer to find a fix (given it's under full warranty), I wanted to check this isn't just a characteristic of the model. I'm quite happy to accept it if it is, I'd feel better knowing it's normal. I don't know anyone else with one to compare. I may try and find the same model somewhere else I can test drive.
Thanks for any input!
Re: Vibration at 2000rpm - 2009 FEH
Sean,
Is it more of a drone than a vibration? With just a slight feel In the wheel?
If so, my 09 has had it since the day I picked it up new. It's been in several times for it, they say it's normal design. I asked why my 08 never did it and was told it's a characteristic of the 2.5 engine. Go figure.
Sean,
Bill,
I REALLY want to thank you for this info.
I'm out of warranty, but I don't care. I despise driving the truck.
I'm gonna take it back to the dealer that gave me this bad info.
Thank you again.
Thank you again.
Do you have anything on:
Premature 12v battery failure (1 1/2 years 37k)
Extremely harsh brakes on first apply (almost locks up at the end of the driveway every morning)
Key insert into ignition (some days the key will not go into the ignition cylinder without great force) this has been replaced under warranty once already but same problem.
The infamous clicking under the dash ( the blend motors have already been replaced under warranty for the hot/cold vent problem , but the clicking persists.
Back window creaks and grinds when going over bumps.
Anything on these problems would be helpful.
We have been trying two different dealers, but each is more interested in excuses than in really looking for the problem.
Thanks again,
Sean
Thanks again,
Sean
Thanks again,
Sean
Thanks again,
Sean
TSB's for '08 FE/FEH. Some are from current model year that go back to at least '08 maybe further. Although the TSB numbers appear as hyperlinks, they just error out for you.
10-13-3
- FM RADIO RECEPTION/SOUND QUALITY CHANGES WHILE DRIVING OR SATELLITE RADIO SIGNAL BLEED THROUGH WHEN USING AUDIO SYSTEM IN AUX MODE
- STEERING COLUMN POP/CLUNK NOISE ON TURNS - BUILT ON OR BEFORE 6/11/2010
- WASHER NOZZLES LEAKING FLUID ONTO HOOD WHILE DRIVING
- VIBRATION/STEERING WHEEL NIBBLE - COLD TEMPERATURES
- CLIMATE CONTROL TEMPERATURE VARIATION FROM SIDE TO SIDE - BUILT BEFORE 12/17/2008
- EXTERIOR HEATED REAR VIEW MIRROR GLASS CRACK WHEN MIRROR DEFROST IS POWERED ON - BUILT ON OR BEFORE 03/31/2009
- LIFTGATE OPENING UN-COMMANDED OR NOT OPENING WHEN COMMANDED WHEN PARKED - INTERMITTENT
- SYNC SYSTEM DEFAULTS TO OR STAYS IN PRIVACY MODE, MULTIPLE VEHICLE LINES
- FRONT AND/OR REAR CREAK/SQUEAK NOISE
- FRONT GRILLE - CHROME PEEL
- CD4E TRANSMISSION FAILURE - REPLACE OR INSTALL TRANSMISSION FLUID COOLER COLD WEATHER BYPASS KIT
- EXTERIOR DOOR HANDLE DIFFICULT TO OPEN/HANDLE NOT SITTING FLUSH WHEN RELEASED/HANDLE STICKING WHEN OPENING DOOR - BUILT ON OR BEFORE 9/1/2009
- CLICK/POP NOISE FROM FRONT STABILIZER BAR END LINK AREA WHEN DRIVING OVER BUMPS - BUILT ON OR BEFORE 10/9/2009
- CLOTH SEAT STAINS WITH WHITE RING OUTLINE - BUILT ON OR BEFORE 5/14/2009 - (EXCLUDES XLS)
- WINDOW TRIM MOULDING - PAINT PEEL - BUILT ON OR BEFORE 3/31/2007
- NEW SERVICE KIT AVAILABLE FOR ACCELERATOR CABLE TO PEDAL CONNECTION
- WHITE FLAKES COMING FROM A/C VENTS
- 3.0L FRONT END ACCESSORY DRIVE RIGHT HAND IDLER PULLEY BEARING NOISE
- ALL WARNING LIGHTS ON IN INSTRUMENT CLUSTER WITH MULTIPLE CODES
- WINDOW SQUEAK - BUILT ON OR BEFORE 8/6/2009
- IGNITION KEY BINDING IN IGNITION CYLINDER WHEN TURNING TO START POSITION ONLY - BUILT ON OR BEFORE 8/3/2009
- RED TRIANGLE ON AND STOP SAFELY NOW MESSAGE - DTC P1A0C
- DTC P0A81 AND/OR P0A96
- WINDSHIELD WIPER PERFORMANCE - BUILT BEFORE 4/1/2008
- NOISE - FRONT STRUT AREA
- ROTATIONAL CLICKING NOISE FROM 17 INCH CHROME WHEEL CLADDING - BUILT BEFORE 2/1/2009 - EXCLUDES HYBRID
- LOWER CONTROL ARM BUSHING INSPECTION PROCEDURE
- PTU VENT BOLT LEAK - MISDIAGNOSED AS PTU SHAFT SEAL LEAK
- 2.3L - FRONT END ACCESSORY DRIVE (FEAD) BELT SQUEAL - MANUAL TRANSMISSION ONLY
- KEY-IN-IGNITION WARNING CHIME - KEY REMOVED - STEERING WHEEL NOT LOCKING
- REAR BRAKE NOISE
- ECVT TRANSAXLE - HIGH PITCH SINGLE TONE ELECTRICAL NOISE
- OVERHEATING - ALL HYBRID APPLICATIONS
- VIBRATION DIAGNOSTICS - STEERING WHEEL NIBBLE - TIRE WHEEL RUNOUT AND BALANCE
- FRONT DISPLAY INTERFACE MODULE (FDIM) - OUTSIDE TEMPERATURE DISPLAY TOGGLES BETWEEN FAHRENHEIT/CELSIUS
- REAR BRAKE NOISE-ROTATIONAL CHIRP - (EXCLUDES HYBRID)
- INSTRUMENT CLUSTER / MESSAGE CENTER - AUTOLOCK / AUTOUNLOCK / AUTOLAMP DISPLAY INCORRECT STATUS / MISSING
- 2.3L ENGINE/CD4E TRANSMISSION ONLY - INTERMITTENT NO START, HARD START (EXCLUDES HYBRID)
- NO CRANK / NO TCM COMMUNICATION / THEFT LIGHT ON / MULTIPLE DTCS - BUILT ON OR BEFORE 3/8/2008
- INTEGRATED KEYHEAD TRANSMITTER KEY (IKT) - INCOMPLETE REMOTE KEYLESS ENTRY (RKE) PROGRAMMING AND/OR DTC B1139
- SLOW FUEL FILL AND/OR DTC P0451
- SLOW FUEL FILL BUILT BEFORE 11/26/2007
- SATELLITE DIGITAL AUDIO RECEIVER SYSTEM (SDARS), MAY NOT SEEK ALL SIRIUS SATELLITE RADIO CHANNELS
- BRAKE GRAB - DAMP CONDITIONS
- CAMSHAFT TICK NOISE - 3.0L 4V ENGINE ONLY WITH EXHAUST CAMSHAFT DRIVEN WATER PUMPS
- MALFUNCTION INDICATOR LAMP (MIL) ON WITH DIAGNOSTIC TROUBLE CODE (DTC) U2062
- 3.0L DURATEC ENGINE - OIL LEAK (LOW AMBIENT TEMPERATURE) - DIPSTICK OR CRANKSHAFT SEAL
- BLOWER MOTOR INOPERATIVE OR STUCK ON HIGH
- WRENCH LIGHT ON - DTC B1239
- WRENCH LIGHT/CHECK ENGINE LIGHT ON-DTCS P2110, P2111, P2112, AND/OR P2135-WITH/WITHOUT DRIVEABILITY SYMPTOMS
- WINDSHIELD WIPER CHATTER/NOISE - BUILT ONLY ON 4/14/2007
- ENGINE NOISE-GRINDING/RATTLE MOST NOTICEABLE AT IDLE-VEHICLES BUILT FROM 4/27/2007-4/30/2007.
- WIND NOISE/WHISTLE - GRILLE
- CD4E TRANSAXLE FLUID WEEP - TRANSMISSION COOLER LINE
- DTC B2572/BRAKE SHIFT INTERLOCK WILL NOT RELEASE - BUILT 01/19/2007-02/12/2007
- CD4E - ENGINE STALLING ON ENGAGEMENT/STOPPING
- LEATHER-WRAPPED STEERING WHEEL - LEATHER COMING LOOSE
- HYBRID - SPILL IN CARGO AREA
