Trouble During Recalibration
Old 11-14-2011, 04:18 PM
GaryG's Avatar
Default Trouble During Recalibration
Today, I was doing great on a 60mpg plus tank and started a recal event. I had a 43% SoC when I noticed I couldn't go EV and the battery SoC started climbing. I got to a 58% SoC , but it would climb no more. Still could get regen, but MG1 would not let it go any higher with the generator. Then I noticed I got motor Assist during acceleration and the battery SoC would drop. Still, no EV mode and I was in this horrible drop in MPG with a battery SoC in the upper 50's. At first, I thought my Hv battery went south, but I noticed my battery fans running hard. It only got to 81F here today, but a recal could heat-up the generator if the Electronic Coolant Pump failed. Also, the battery could be over heating if the battery A/C wasn't working. Looks like a first for me at any point. I'll be doing some more test to see what the problem is, but does anyone have any guesses?
GaryG
Old 11-15-2011, 04:43 AM
subdewd's Avatar
Default Re: Trouble During Recalibration
So you think it was a recal that wasn't completed because of an external fault?
What was on the odometer? or pehaps not a recal and somehow just went past normal
SOC during regen?
Old 11-15-2011, 05:53 PM
GaryG's Avatar
SOC during regen?
I think overheating of the generator or HV battery was preventing a recal completion. I'm still stuck in this mode until a cooling matter is repaired or the HV battery is replaced. I'm leaning to an Aux A/C issue, but have not had any time to investigate yet. My odometer is at ~30,100 miles, but I don't think that is in play at this point. I never run my cabin A/C, but the Aux A/C runs all the time in my hot weather. I've never had a battery blend door trouble, so I don't think that's an issue. This is the first time for prolonged non-EV mode, so heating must be the problem.
GaryG
Old 11-17-2011, 04:27 PM
GaryG's Avatar
Okay, I haven't had time to test the MECP or the A/C, but when I came home today I think I'm closer to knowing what was causing the EV problem. Under the left front of my '09 FEH was a large wet spot and something is now dripping. This just started within the last 4 hours and it appears to be MECP fluid. I haven't started or moved my FEH since I parked it before my post here. I haven't heard that the pump will leak when it goes bad (anyone?), so it might be just a leaky hose or something.
GaryG
Old 11-17-2011, 08:39 PM
eldiee's Avatar
I thought in the 2009 and newer Escape Hybrids they had an entirely new pump that was to solve the problem some of the older models experienced.Is this not the case?
Old 11-18-2011, 05:08 AM
subdewd's Avatar
I doubt it is the blend door since you'd get the service light and wrench, I just replsaced mine @ around 30k. I was getting intermittent service light. pretty easy repair, definitely no a $800 dollar job, took less than 45 minutes.
If it was the A/C wouldn't it go back to normal after cooling down to ambient temp over night?
stevedebi
02-02-2011 03:16 PM
morgante
09-14-2010 09:37 AM
Tim K
06-09-2008 08:32 AM
AJR
08-21-2007 09:20 AM
lrondrunkard
08-11-2006 09:36 PM
