tire pressure monitor questions
Old Oct 1, 2009 | 01:09 PM
Transient's Avatar
Question tire pressure monitor questions
I have a 2008 FEH and this year I am planning to buy some winter tires and rims. As I understand it, the tire pressure monitor is somehow part of the valve stem, so I would have to install them on the new tires and they're not exactly cheap.
I was wondering exactly what would happen if I just simply didn't have them? Obviously the tire pressure monitor wouldn't function, but is there any negative to that?
Also, I presume the dash indicator is probably going to light up. Is it just a solid light which I can easily ignore, or is it more intrusive (blinking and beeping)?
Old Oct 2, 2009 | 04:56 PM
stevedebi's Avatar
Default Re: tire pressure monitor questions
I know that if you have a single low tire, the light is illuminated, just a steady light. However I'm not sure what would happen if there were no sensors at all; it might throw a different code.
Why not just get new stems?
Old Oct 8, 2009 | 07:13 AM
Slick's Avatar
Mine went off last week...solid light in the dash and the info center said "low tire pressure"...no idea about the valve stems though.
Old Oct 8, 2009 | 08:21 AM
stevedebi's Avatar
OK, the obvious, did you check your tire pressures?
Old Oct 8, 2009 | 08:24 AM
Slick's Avatar
yeah right away and it was right, slow leaker drivers rear, under 30 psi I'm thinking set it off? Been a few days now, meant to check it again and keep forgetting...hasn't gone off again yet but need to use a gauge on it...
hc45
Aug 3, 2013 06:29 AM
UTAlumnus
Aug 20, 2011 03:40 PM
Oiler
Jul 19, 2007 06:50 AM
CrisCross
Oct 16, 2006 11:30 PM
mg48
Jan 13, 2006 07:53 AM
