System Check doesn't detect Bad Brake Light
I'm replacing my first failed light bulb on the FEH, a 4157 brake light. Even though the bulb is failed it is not detected by the "System Check" function which still reports "Exterior Lights OK".
Even the owners manual (pg 101) shows a warning message for "Check brake lamps". Obviously this function doesn't work. Anyone else have any experience with this?
Re: System Check doesn't detect Bad Brake Light
Gary
On my 2008, when my brake bulb went out, the turn signal blinker started going very rapidly when used. Ford tends to do that sort of thing to indicate a bulb is bad. I didn't do a system check - I just replaced the bulb.
^^ On the '07 the brake and turn signal are on separate bulbs, so losing a brake bulb doesn't effect flash rate of the turn signals.
I'm still puzzled that Ford would implement a feature, and document it, like the brake light test and it just doesn't work with their OEM bulbs.
The Ford Workshop Manual mentions a overheat condition on the rear end of a 4WD/AWD equipped model, what to do if it does, yet there is no indicator to inform you of this condition. There isn't a temperature sensor in the unit either. Just another documented item that "seems" to be not there.
Supposedly, Ford does. It states when this condition is encountered your supposed to pull over, let it idle till the condition stops. Forgot to mention that it also states when this over temperature condition happens the rear end will lock up full or 100% to aid cooling.
If this happens one hint would be that it woold resist turns because of the 100% lock up. If your on dry hard pavement, it real good way to break something too. No slippage, things go boom!
This is in the Ford books and has been for some years.
drabood
06-18-2014 05:57 PM
cak615
10-28-2013 09:11 PM
SadCarTime
07-09-2012 09:05 AM
