Sync Microphone kit TSB
Ok, so I have the external microphone installed to fix the problems with background noise and all is working well for about 9 months. Then the mic stops working. I plug the wires from the mirror mics into the connector and confirm it is in fact the mic that has gone bad.
Get the usual run around at the dealer, they say " it's ~400.00 to fix, but we will fix it if you pay the $50 deductable (I'm out of warranty). Smelling something fishy, I do my research and the part is $49 at the parts counter at the same dealership.
So I buy the part, replace it myself (<5 mins) and all is working fine......For just under 2 months.....Then it's out again
The dealership replaces the mic under the parts warranty and I put in in yesterday and all is well again.
So my questions are:
Defective parts????
Something killing them? I measured the voltage to the mic on the Blue (+12) and Braid (Gnd) and it measured 13.5vdc.
Has anyone else had the "upgrade" and had additional problems since?
Defective parts????
My wife had her mic diagnosed as "bad" when they did the Sync 911 update about 4 months ago and we took it back for call quality problems. (It was fine before the update.)
Knowing how lousy the phone quality can be when using Sync, I asked about the TSB and was told they'd know when they do my 911 update if the mic was bad. (They didn't replace mine, tho I'd like to have it replaced.) Both our vehicles are about the same production date, but only mine is a hybrid.
I originally demanded that they install the black external microphone because the in-mirror mic design is horrible for call quality. I am much happier with the new mic with the exception of the failures.
I like how they have changed the design in 2010 vehicles because they realize that there is a problem.
I had to work with 2 dealerships at the same time to get the TSB done and the external mic installed. It also doesn't hurt to have the TSB in hand in case they try to give you the run around.
TSB 10-8-4 superceded 10-4-8. It's a 30MB PDF with lots of pictures which is much too big to attach here. It says the changes were vehicles added to the list of affected ones.
Thanks Bill, I was concerned that they may have identified a problem that is causing the mics to fail. 1 week now and its still working........
If it fails again I am going to Ford directly.
Just came back from the stealership and have a new external mic on order for my wife's MM. Her first external mic died and mine (also external) also appears to be dead so will have to schedule time to take mine in again.
