Re: Steering Wheel Buttons
Originally Posted by DavidH
(Post 133643)
I expect the whole cruise control design is different on the hybrid. Hybrid cruise must develop a call for torque signal, while the non-hybrid uses an cruise control actuator to position the throttle.
Well, it looks like as of December the FEH and MMH are shipping with the redundant audio controls on the wheel. Let's see if we can find out what it costs for a retrofit.
I'll ask my dealer - maybe others can check too; I picked my car up on 1/3/08 - an 08 MMH - and would really have liked this option (I listen to an iPod through the Aux jack, and audio levels on Podcasts are all over the map, requiring constant knob twiddling). I'm betting it's prohibitively expensive, but it never hurts to ask... |
Originally Posted by bmisf
(Post 156663)
Let us know what you find out.... |
I know someone (here?) checked out the controls on '08 Escape Limited, and reported that even the steering wheel is slightly different. If that is true, then could see it being in the hundreds of dollars.
I had looked into the retrofit idea. I had been told:
1) the omission was an oversight :angry: :confused: 2) that Ford engineers designed the 'new' wheel (with audio) with a cruise circuitry NOT COMPATIBLE with early-built 08 hybrids :angry: :angry: The only course at this point would be an aftermarket, or to hit Ford up to design a retrofit product for dissatified owners who got screwed for 'coming to the 2008 party early'. I think the podcast/volume issue mentioned here is a good one to help build a case. I myself have found the audio knob on the Nav radio small and hard to control while the vehicle is moving. I would pay the bucks--as I plan(ned) to keep the vehicle for awhile. Bottom line- collective voices need to be heard. Ford does nothing without getting hammered in mass. My suggestion-call your dealer and complain. Call and email Ford Customer Service and ask your opinion be forwarded to the Escape brand manager and development team. I try and find out a name, so stay tuned.... |
Originally Posted by icebluemariner
(Post 156921)
1) the omission was an oversight :angry: :confused: 2) that Ford engineers designed the 'new' wheel (with audio) with a cruise circuitry NOT COMPATIBLE with early-built 08 hybrids :angry: :angry: Of course the design needed to be different. There are more buttons so the steering wheel itself needed to be changed to accommodate them. Plus, there needs to be support for those additional buttons so the wiring harnesses and plugs need to change. After an entire year, did you really expect nothing to change at all? |
Originally Posted by WaltPA
(Post 156944)
Icebluemariner - where did you get your informaiton? Does this mean that there was a change to the Nav system hardware mid-run? |
The clock spring also needs to support the additional wiring. But, my steering column and wheel look the same except for the missing buttons. Is there any steering wheel/steering column function that is unique or speciial to the hybrids?
Let me clarify: The Job 1 of the new generation 2008 FEH/MMH did not have the redundant audio controls (rac). I have it on reliable information that there was no conscience decision to OMIT the RAC from the wheel, as they were part of the build on the gas version Escape Limited. This was brought to Ford's attention, and presto! They were planned and built as standard on all Job 2 FEH/MMH. So error/oversight...call it what you will, but it slipped through the cracks.
I did find it odd that not only could this have been an oversight, but that Ford would actually changed cruise control circuitry between builds between Jobs 1 and 2 for the same model year. It would have been more expected if we were talking about a 2009, but since MY2008 rollout in Feb 07, the omission was caught, went through enginerring and was announced in the November order guides. |
And the steering wheel housing for the 08 FEH/MMH is exactly the same. The base wheel (without audio controls) has the same characteristics, with the exception that the mold did not accomodate the audio control switch. A retro from a wheel without the switch to one with the switch could have been done, were it not for the change in the cruise circuitry....
