Seat Cover Install Problem?
In order to install the covers, I need to remove the hard plastic trim around the front seats. Any ideas?
Thanks...Dan. |
Re: Seat Cover Install Problem?
I had seat covers made by Coverking and didn't need to remove the plastic trim to install them. I simply fished the elastic tie down with hook between the seat and the plastic and then pulled it through a hole out the bottom.
Do you have full curtain air bags? If so do not cover the sides of the seats. If there is a sticker on the outside part of the seat backs that says airbag do not cover them....
I believe that Wet O-kole (spelling ?) also makes custom seat covers that are safe to use with seats with airbags. |
There are no airbags in the seats, I can try the fishing between the plastic but would prefer to remove the trim.
Thanks for the help...Dan. |
