ScanGauge Data, Xguage & readings
Old Dec 19, 2008 | 03:21 PM
08hybridok's Avatar
Default ScanGauge Data, Xguage & readings
So every once in a while I get this idea of why we don't have a thread/stickey with the SC Codes to plug in. And to up it a little what the codes should read, like normal, min, max, and special notes.
I know Carl(?) DD, has an image in the photo section I refer to, and even recently went to SG's site which is updated with most codes, so they can be found relativly easily. But to find them, and know what they should read is 2 differnt things.
Personally I'm a good follower, you give me instructuions I can read & do, but a lot of times I may not understand what I'm doing, just the final result. If I know more of what these codes mean I might be able to do better
I was thinking a xls spead sheet would be easist format. Even better would be a way to post it in open format we could all add our own notes, but not sure how to do that.
Something like this attached file:
UPDATE: 12/29/08
Small updates, Can't find the FWT code
DD Is the correct CHT listed?
I am also able to save to a htm file for easy viewing, or anyone that can't view an xls file:
http://www.geocities.com/bryanw20@sb...t/SGxCodes.htm
File Type: xls
Old Dec 19, 2008 | 04:18 PM
Default Re: ScanGauge Data, Xguage & readings
Interesting format you created. Maybe this format can be created by this forum administrators for posting in the scanguage thread.
Old Dec 19, 2008 | 04:24 PM
colchiro's Avatar
Ideally you'd want the file in an area where people can download, but one person is responsible for corrections and has access to the file for updating. (ie., just one copy exists.)
BTW, no personal info in the file. Good job.
Old Dec 19, 2008 | 05:58 PM
Yet you need to allow for differences due to a variety of factors: such as ethanol % in the fuel--towing loads--temperature extremes
Old Dec 19, 2008 | 08:16 PM
08hybridok's Avatar
That's why I'm afraid a spreadsheet would be very wide. Different years, FWD/AWD, different gas, summer/winter, etc. But maybe simply Avg the results togather, say the 3-5 (more less depending on how many results) to get an avg min/max value. Some I know are pretty hard coded like SOC, 41% is pretty guarnteed ICE off, yes it can go lower, as well as over 53/54% but not 'normaly' that's where the notes comes in. FwT I'm sure is another, 'normal' would be xxx-yyy, but 200+ is high, <32 would be bad (I assume; but guess that's why we use antifreeze/coolant not just water)
I think I'm up for the task of compiling, and updating the spreadsheet regularly, but I'd definatly need help getting figures.
I'm hoping to 'borrow' Desert Dog's, GPSMan,Gary's, etc's work to save some typing at least on the codes. (Sorry I'm bad w/ names)
I plan to compile #'s found on this board, plus what anyone wants to add/send in directly. I need to browse cleanmpg.com as well, I havn't gone to that site at all, so if anyone sees a good thread, you can PM it to me, thanks.
Old Dec 19, 2008 | 09:52 PM
08hybridok's Avatar
Just a 'bump' to show I updated the data (in the first post)
Also what is 'critical' SOC, if one were to say sit in N with the radio on, 1) will the HV batt protect it self and shut off/revert to 12V battery & 2) when is it to low to start, require a 12V jump?
Old Dec 20, 2008 | 12:54 AM
This is kind of what I was getting at / looking for with the ScanGauge Data Depository Sticky at the top of this forum.
I've posted what my car, a 2005 does, and Billy has done the same, and so have some other people.
If you wish to tabulate into a chart, then fabulous.
Feel free to utilize the Sticky we have already started.
-John
Old Dec 20, 2008 | 08:57 AM
08hybridok's Avatar
-John
Thanks John, that was my next step. to take in info off the board(s) and start crunching #'s
That should give me 'normal', not sure if physical max/min will be that easy, unless someone knows that xxx can not exceed yyy, and if so, how do they know this?
Old Dec 20, 2008 | 12:15 PM
The service manual ( not owners manual ) states what are "normal" values for many items, and gives min/max for certain things.
But you are right, for certain things it will be by experimentation.
Old Dec 20, 2008 | 12:26 PM
DesertDog's Avatar
I would remove all the ones from the Linear Logic website. They have not updated or corrected the list in more than a year. For instance, the MxC and MxD are in kW, not amps and the scaling is .25, not .5. I posted that correction here a long time ago, but it seems to have not taken. Also, the 4WD apparently doesn't work. It was a guess on my part but I didn't have an AWD FEH to verify it. The HV current xgauge is bus-eavesdropping and is the actual current in/out of the HV battery and works correctly for both positive (discharge) and negative (charge) current.
I have had the SoC drop to 23% when working on the car before and it started fine.
