Scan Guage Install
My OBD plug is right behind the Emergency Brake Release. I'd like to mount the Scan Guage on the steering wheel fairing right in front of me. Any tips on snaking the wire and bundling the excess?
Thanks, John Dixson |
Re: Scan Guage Install
Originally Posted by Johndixs
(Post 157464)
Thanks, Kristian. I was hoping that it was possible to thread the lead thru the flexible/floppy black rubber seal that surrounds the steering wheel shaft and fairing assembly as it adjusts vertically. It is very difficult to get one's head and hands into position to do anything where you can see what is going on!
This is how I originally had mine installed & it worked great:
http://www.pbase.com/jmorton10/image/79877382 I now have two of them right next to each other in the same location & the cords do not show at all. I use one for proprietary hybrid functions & the other for trip-meter type stuff. ~John |
I like having mine on top the dash, far left, touching the windshield pilar. The wire goes inside the back rubber at the door jam, and then quite easily inside the dash. Cords are invisible. Here, it is in my line of sight, and I can pretty much watch the road and the SG at the same time. ( just a change of focus on the 'ol eyballs )
:shade: -John |
JMorton, I have a 2008, so the instrument panel is slightly different, but having spent 1962-2005 in a cockpit, I tend toward having things in front of me, as in your installation. Looking at your picture, I am thinking of mounting the SGII a bit toward the driver position, on top of that fairing that covers the steering wheel shaft. With my normal seat height, that will enable me to see the SGII AND all of the information on the instrument cluster. Now I just have to confirm that I can get the wire from the back of the SGII, by the rubber flap around the steering wheel shaft, behind the instrument panel, and then loop it around to the connection port. Thanks for the tip.
