Rearview camera systems
Old Jan 8, 2013 | 07:13 PM
us035976's Avatar
Default Rearview camera systems
Has anyone installed a wireless rearview camera system in their FEH? I noticed that I have a much harder time determining how far I am from another vehicle when backing up than I used to in a car.
Looking for any recommendations on a good system for $100 or less. Then I have to figure out where to mount the monitor... Already have a dashful with my GPS and Scangauge.
Old Jan 9, 2013 | 01:30 AM
pintuhs's Avatar
Second Hand Cars
Default Re: Rearview camera systems
made-in-china.com is the huge portal of automotive parts & accessories. You can find latest range of Back-up Cameras & Water Resistant rear view Cameras.
For more details Latest Gadgets necessary for your Car go-through this article @ usedrvs-motorhomes.com
Old Jan 9, 2013 | 10:02 AM
stevedebi's Avatar
Mine came with the rear sensors, which "beep". They are invaluable. Those are also available cheaply as an alternative.
Old Jan 9, 2013 | 12:33 PM
GatorJ's Avatar
You get spoiled with them, too. I have to remember my other vehicles are not so equipped.
Old Jan 10, 2013 | 05:03 AM
us035976's Avatar
I checked those out and decided to go with the ultrasonic sensor setup. I ordered one, we'll see how that works.
Thanks for the tip.
Old Jan 10, 2013 | 09:11 AM
stevedebi's Avatar
My wife had me install it on her 2002 Civic - she liked it so much from my FEH!
Actually, when I was shopping back in 2008, I really wanted a blue MMH. But the one I own was the only one out of 40 on the lot with the backup sensors - so that is the one I bought.
Old Jan 13, 2013 | 08:11 AM
Backup camera location:
comes thru the double din headunit:
No it is not wireless.
Old Apr 25, 2014 | 09:50 AM
TBH's Avatar
TBH
Are you saying that you were able to hook this aftermarket camera to the existing NAV system? I'd like to do that.
Old Apr 25, 2014 | 10:11 AM
GatorJ's Avatar
Not to the factory system if that's what you're asking.
Old Apr 25, 2014 | 11:33 AM
xspirit's Avatar
Mine has them also. They work much better than I expected, "seeing" things low like curbs, and things off at an angle while you may be backing up and turning at the same time. You immediately learn what distance the tone timing means, and you can use it to back within inches of obstacles. I have never backed into anything using it, and my parallel parking etc. is far more accurate.
Just beware of "front end swing".
I recently drove an Aucra RDX with a rear-view camera. As I wasn't used to it, I backed into something. It turns out you have to learn that the view on the screen is distorted and doesn't convey actual distances.
Worse, your eyes are busy looking at the screen and can't do anything else at the same time. With an audio/sensor system, you can be looking around while at the same time using your ears to listen to the tones to gauge distance. Such as when backing into a parking spot, you may want to be looking to see if you're straight and the front end is lined up, while listening for rear clearance. In this respect, the sensor/audio system is much better than the camera.
