No Power steering assist for 2 seconds.
Hi Guys,
I own a 09 AWD ford Escape Hybrid, with 13,000 mile now.
This just happened to me on my last trip to Tahoe last weekend.
I was driving past Clear lake on my way to Tahoe and it was a curvy mountain road, as I started a turn at 55 MPH I had NO p/s assist.
I immediately hit the brakes and it came right on, so for 2 seconds the power assist did NOT work.
I drove all week in Tahoe and it did not return, BUT THIS SHOULD NEVER HAPPEN.
Two months ago I was backing out of a parking lot and it happened for the first time after 2 seconds it started to work also.
Any one else had this problem.
Time to look at the NTSB site.
Mark
Mark
I have also experienced this once on my 09 FEHL and I am still cleaning the seats because of it
I would like to hear if others have seen this or a recall related to it.
I also have a 2WD 2009 FEH, and this happened at the 10K mile mark--just briefly in city driving. It has not happened since, and I'm at the 13K mark. I'll stay tuned on how you get this fixed. Thanks.
If you get the old song and dance that it didn't do it on our test drive, no trouble codes and Ford never heard of the problem? Make sure you file a report at the NHTSA site.
I almost got T-boned Monday afternoon in my '09 FE while making a lefthand turn when the accelerator didn't respond, no engine revs, nothing at all. All of a sudden, it roared as I probably had it near floored by that time and just barely got out of the way of oncoming traffic!
I also noticed that their test drive was a big 1.5 mile trip too! I'd had 3 or 4 times while coasting to a stop but not fully stopping and back on the accelerator when I've felt this. I thought that it might be a not so perfect transition from DFCO but it never happened while turning before. Not sure if it's a throttle/drive by wire issue although one can find many complaints about a slight delay in accelerator response but this was slight at all!!!
I explained how/when/where it happened but they had little concern about my safety, so I filed a report with NHTSA. If they would have at least tested something but they didn't. Problems don't always generate trouble codes and that's even in their own manuals.
OK I got the Song and Dance but that it what I expected. SO I will be working my way through the problem 1ST I will call ford motor company if they WILL OR won't help me out, 2ND I will file with the NTSB.
BUT if they refuse to help and ALL of us with this problem start to scream at the press
we might get someones attention.
More on that later.
Mark
More on that later.
Mark
More on that later.
Mark
More on that later.
Mark
What gets me is that this like yours is no doubt a safety issue. I retired from Ford and worked in maintanence. If there was a near injury situation or a injury that happened on or with a machine, something was always done, always! It might be adding a switch, changing the program, adding a guard, etc. None of which may help the situation but at least something was tried! I our case, they blow us off and that's sad.
