new FEH 08 2WD 110V power outlet
Hello,
first of all, I am a proud owner of a new FEH 08 2WD. I had it for a 1 week. I am already happy with my MPG that is 29. I just made about 300 miles with that SUV. However, I have a problem my 110V outlet fleshes green, I tried to connect my loptop with it few times for the past week by the outlet still falshes green. Before I will contact the service I would like to ask you guys what do you think ? I didn't find anything in the manual.
please help
thank you
please help
thank you
Does it flash when you plug your laptop into the outlet or before. I have one on mine but have never used it. BTW the 110v power outlet is an option on the 07 and back.
it flashes all the time when the car is ON.
Also, if somebody can check if 110v plugs "blinks green" or is a steady green light.
thank you for any hint and help
thanks
No,.... It is steady green whenever the key is in "run" position.
( In 2005 to 2007 that I know of )
Flashing means there is a grounding error or overload error.
I don't have my manual with me now, but flashing means there is an error.
It is easy to over-load one of those, ( only 150 watts ) but a laptop should not do it under normal conditions. My laptop takes 60 watts.
-John
-John
On the '06 its a steady green. I thought flashing green meant an overload condition. MOST laptops shouldn't overload it but a few I've seen (desktop replacement types) would. Also... devices with switching power supplies in them (laptops, battery chargers, etc) tend to be a bit harder on DC/AC converters. The 110V plug likely doesn't actually put out a sine wave like normal AC. It probably puts out a square wave step function equivalent of one... some electronics don't get along well with that, switching power supplies among them.
thank you all, it seems I will have to service it - and it sucks I just bought it. Well, I still love the car but I wish I wouldn't have a problems like that. Meanwhile if anybody would have any idea - please help.
thank you all
thank you all
One symptom of overload is it gets too hot.
This would make the light flash, and turn the power off to protect itself.
When it cools down, it is supposed to reset, and not flash.
I assume you have tried it when it, and the car are at room temperature?
If it still flashes, and you are sure it is not to hot ( and parking in the hot sun could make it too hot without anything pluged in ) then something is wrong.
It should not cost you anything, and it should not take much time to swap it out if that is what they need to do. Just call ahead and make sure they have a replacement on hand, and you should be in and out in 1 hour or less. Also check the fuse box. I think there is a separate fuse for the power outlet and the little green light, so the main fuse could be blown without it affecting the little green light. Good luck!
thank you all
My 06 flashes at times, but I have noticed that if I plug something into the 110v outlet BEFORE I start the truck it always works fine. If I start the truck & then plug something into the outlet, half the time it doesn't work.
~John
~John
